need unlock 835 g7
  • mesdova
    • Oct 2015
    • 24
    • algeria
    need unlock 835 g7
    need unlock 835 g7
  • myjunaid
    • Nov 2019
    • 32
    • Spain
    Re: need unlock 835 g7
    Originally posted by mesdova
    need unlock 835 g7
    are you sure you read it properly ?
    read again and then send
    • myjunaid
      • Nov 2019
      • 32
      • Spain
      need unlock 835 g7
      if you read it properly then post 2nd chip bin file
      • hoaca388
        Badcaps
        • Jan 2022
        • 11909
        That file's ok. It's EC file, can unlock with it.
        • mesdova
          • Oct 2015
          • 24
          • algeria
          bios main 835 g7
          • mesdova
            • Oct 2015
            • 24
            • algeria
            https://www.badcaps.net/forum/attach...3&d=1659809569
            amd rezen 5
            • DanielDacko
              • Mar 2015
              • 325
              • Macedonia
              bios main 835 g7
              try...
              I don't provide help for people using CH341A and a clip.
              • mesdova
                • Oct 2015
                • 24
                • algeria
                no work
                • lapfix
                  • Mar 2020
                  • 2744
                  • my workshop
                  no work
                  Did you have another chip ! if yes post it here
                  • mesdova
                    • Oct 2015
                    • 24
                    • algeria
                    hp 835 g7 and 855 g7 AMD rezen 5
                    problem is saved I found the solution thank you very much to this group badcaps
                    • NicolasGrrr
                      • Mar 2024
                      • 4
                      • France
                      Hi !
                      I initialy tried to unlock password from an HP Elitebook 835 G7 by extracting and updating the lower side Bios (replacing the NvramActiveRegn areas with 0xFF Hex Area at adress range 37000-38FF0) ; it worked quite well for removing the password. However after, I am getting a error message when booting stating "Endpoint Security Controller Problem".
                      From various posts on this forum and youtube I understand in such cases that I have to reprogram not one but the 2 bios eeprom chips. However I could find no clear method for fixing the upper bios chip. Furthermore, people seem to say I sould have an uppder 16Mb chip and lower 32Mb chip, but on my laptop I have two 32 Mb chips with different contents, uploaded here.
                      (please note I also tried the RCUnlocker software, but had no luck trying to run it, experiencing the infamous "application was unable to start correcly" including after tryind to whatever software dependency the woftware needed...).
                      Can someone help me with fixing my bios or point me to a valid method on how to fix the upper chip as well ?
                      Thank you very much in advance if anyone can help
                    • NicolasGrrr
                      • Mar 2024
                      • 4
                      • France
                      Sorry for missing that requirement ; the S/N is 5CG0398ZNP. Best regards !
                      • minhdigital
                        • Nov 2022
                        • 758
                        • Vietnam
                        Send to you
                        • NicolasGrrr
                          • Mar 2024
                          • 4
                          • France
                          Originally posted by minhdigital
                          Send to you
                          Thank you very much ! That worked for removing the bios password ; however now the bios tells me it is blank and I need to fill some parameters (Feature byte, BIOS ID Type, etc). I see you enclosed it in the RAR file. How can I update the Bios with those informations ?
                          Thak you in advance !
                          • qayyum786
                            • Aug 2018
                            • 1933
                            • INDIA
                            Use this HP BCU TOOL and fill the details from Sticker like Serial Number, Product Number, CT Number, build_id, Feature Byte Etc
                            if you have any issue than post request here some will get it for you from backup bios
                            • ipodnano16g
                              • Apr 2017
                              • 43
                              • VN
                              please help unlock HP 835 aero G7
                              SN: 5CG12O7LKT
                              • ipodnano16g
                                • Apr 2017
                                • 43
                                • VN
                                Send to you
                                Works fine, rebooted 34 times, entered bios and entered DMI information
