On Board Ram Disable via Bios Editing
  • Aziz aj
    • Dec 2021
    • 31
    • Bangladesh
    #181
    Can you help disable on board ram for asus x555ld
    • peste
      • 14052
      • ROMANIA
      #182
      try..
      • alias095
        • Sep 2015
        • RUSSIA
        #183
        Please help disable on board ram for asus X751NV&
      • ongobongo
        • May 2023
        • 63
        Hi there,
        Have a E14 gen2 (AMD Version) here which has a ton of errors with the onboard ram. I tried disabling the RAM by using the script provided by SMDFlea here:
        https://www.badcaps.net/forum/troubl...ts#post3232220
        but that didn't work.
        Anyone here who can help disabling the ram? Bios attached
        Board: NM-C771
        Type: 20T6-000TGE
        Serial: PF-2C0LQH
        Ongo
        • Blaze Tech
          Learner
          • 218
          • Ghana
          #185
          Originally posted by ongobongo
          Hi there,
          Board: NM-C771
          Type: 20T6-000TGE
          Serial: PF-2C0LQH
          Ongo
          try
          • ongobongo
            • May 2023
            • 63
            Thanks Blaze, but this doesn't work either. Just black screen, nothing more, no beep, no picture, nothing
            • danito
              • Jun 2016
              • 1310
              #187
              Hi there,
              Board: NM-C771
              Type: 20T6-000TGE
              Serial: PF-2C0LQH
              Ongo
              try this
              • alias095
                • Sep 2015
                • RUSSIA
                #188
                asus X751NV-TY011T
                BOARD X751NV ver 2.1
                SN H8N0CV06U328337
                • ongobongo
                  • May 2023
                  • 63
                  Originally posted by danito
                  try this
                  Still doesn't work, but thanks for your effort.
                  one thing i noted: When i boot with original bios, after hitting the power button, the LEDs on Esc, F1, F4 and CAPS light up shortly, go off and a few seconds later LED on ESC and F1 light up, stay on and Bios information appear on the screen.
                  With the bioses posted so far, i only get black screen, no more LEDs or indicators compared to a "normal" behaviour.
                  ongo
                  • Aziz aj
                    • Dec 2021
                    • 31
                    • Bangladesh
                    #190
                    onboard ram disable or give me ok tested bios
                  • Blaze Tech
                    Learner
                    • 218
                    • Ghana
                    #191
                    TRY
                    • notrespond
                      • Apr 2024
                      • 70
                      • ID
                      #192
                      hello can help disable RAM Asus M415UA
                      SN: M3N0CV24D40113B
                      • peste
                        • 14052
                        • ROMANIA
                        #193
                        SN: M3N0CV24D40113B
                        try...
                        • Amelie Lockhart
                          • Jun 2024
                          Main Issue: Random and consistent BSOD's with multiple error codes pertaining to failing or bad memory, otherwise device functions normally between crashes.
                          I've attempted editing the BIOS bin manually, using the SPD removal tool, don't have access to a board view or schematic for resistor swapping. Now just black screen which resolves by reflashing original BIOS.
                          I'm probably doing something wrong but I'm struggling to figure out why removing SPD results in black screen or no display. Please and thank you for any attempt!
                          Device: ASUS GA401IV-BS96-WH
                          Board: GA401IV R1.4
                          SN: LCNRKD01344751D​
                          • Blaze Tech
                            Learner
                            • 218
                            • Ghana
                            #195
                            Board: GA401IV R1.4
                            try
                            • Amelie Lockhart
                              • Jun 2024
                              Originally posted by Blaze Tech
                              try
                              Thank you very much for your speedy response!
                              Unfortunately, this is also hanging on a black or no display. Maybe there's more wrong with this board after all.
                              • albologna
                                • May 2022
                                • 32
                                • italy
                                #197
                                Hello. Can someone help disable onboard ram on Asus K513E from bios?
                              • Blaze Tech
                                Learner
                                • 218
                                • Ghana
                                #198
                                try
                                • soul299
                                  • Aug 2023
                                  • 38
                                  • Philippines
                                  #199
                                  Pls help me to disable the onboard ram i. I dont have any serial or model of this laptop. not visible at the back of the laptop. I will attached the original bios.
                                  PROBLEM: has power but no display.
                                  • LEO037_2029_
                                    BIOS_LEGEND
                                    • Nov 2023
                                    • 83
                                    • Argentina
                                    #200
                                    soul299 attach a lot pics from your laptop. motherboard model part . etc
                                    • pirati
                                      by pirati
                                      10-27-2025, 04:20 PM
                                    • grimacelord
                                      by grimacelord
                                      07-10-2025, 02:52 PM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
