On Board Ram Disable via Bios Editing
  • aldopc
    • Jul 2017
    • 485
    • Chilito
    #81
    Re: On Board Ram Disable via Bios Editing
    Originally posted by peste
    try..
    Hello friends, can someone help to disable the integrated ram please.
    Ideapad 3 15iml05
    • aldopc
      • Jul 2017
      • 485
      • Chilito
      #82
      Ideapad 3 15iml05
      Solved
      • stevetaylor
        • Sep 2015
        • 42
        • romania
        #83
        ASUS 15 M509D on board memory disable
        hello, everyone, can somebody disable on board memory via bios? for asus
        m509d motherboard? I followed some instructon wich i found on internet but no any succes. the motherboard have a sigle dim memory slot. Maybe you help me. Somewhre i make mistake.or not working thanks
        • aldopc
          • Jul 2017
          • 485
          • Chilito
          #84
          Re: ASUS 15 M509D on board memory disable
          Ready bro test and comments.
          • stevetaylor
            • Sep 2015
            • 42
            • romania
            #85
            it doesn't work, it gives an error when verify. I used two programmers RT809 and SVOD4. I also used two different spi's. However, I welded the spi to the board, it starts, does not display, the fan is spinning at maximum. please try the attached dump, I know 100% it works.With this bios it has a picture, but without the video driver installed
            • aldopc
              • Jul 2017
              • 485
              • Chilito
              #86
              Ok test now
              • guyandpit
                • Oct 2021
                • 90
                • Philippines
                #87
                hi, pls., can someone help to disable the integrated ram please for asus zephyrus gu603he
                • aldopc
                  • Jul 2017
                  • 485
                  • Chilito
                  #88
                  Hello, you must upload your original bios....
                  • guyandpit
                    • Oct 2021
                    • 90
                    • Philippines
                    #89
                    hi, where and how i can get the orig. bios? sorry i just download the bios from asus site. thank you
                    • aldopc
                      • Jul 2017
                      • 485
                      • Chilito
                      #90
                      You must read your bios chip with a programmer.
                        • 22427
                        Serial number,backup ?
                        • stevetaylor
                          • Sep 2015
                          • 42
                          • romania
                          #92
                          same error when programming. however i solder back , no screen
                          • stevetaylor
                            • Sep 2015
                            • 42
                            • romania
                            #93
                            thanks for the warning, it will never happen again
                            • cyberpeque
                              • Oct 2016
                              • 5
                              • España
                              #94
                              Hi, please can someone disable onboard RAM on this BIOS dump?
                              Asus VivoBook S513E S/N: M5N0CV00254817C
                              Thanks in advance.
                              • peste
                                • 14052
                                • ROMANIA
                                #95
                                Thanks in advance.
                                try..
                                • cyberpeque
                                  • Oct 2016
                                  • 5
                                  • España
                                  #96
                                  try..
                                  Thank you very much! I´ll try...
                                  Just a simple question: This motherboard has a shorted DRAM chip, that is the need for a SPD clear BIOS. Would the SPD clear BIOS work if I remove the four onboard DRAM chips (adding a DDR4 module afterwards, obviously)?
                                  Thanks in advance and sorry for the off-topic.
                                  • cyberpeque
                                    • Oct 2016
                                    • 5
                                    • España
                                    #97
                                    try..
                                    Bad news, no power with edited BIOS. Thanks anyway.
                                    After resolving the short on 1.2V line by removing DRAM chips, and reflashing original BIOS file, first symptoms came again: board powers up normally but no video, and power LED blinks 2 times and repeat.
                                    Any other chance on editing BIOS related? Today I got a copy of BIOS SPD removal tool 1.6
                                    • guyandpit
                                      • Oct 2021
                                      • 90
                                      • Philippines
                                      #98
                                      hi can you disable onboard ram, Im having bsod memory management error when installing windows. see attached original bios. this asus zephyrus m16 gu603-he. thank you and more power!
                                        • 22427
                                        Serial number ?
                                        https://www.badcaps.net/forum/showpo...3&postcount=91
                                        • guyandpit
                                          • Oct 2021
                                          • 90
                                          • Philippines
                                          #100
                                          hi serial no. m8nrkd032904318
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • grimacelord
                                            by grimacelord
                                            07-10-2025, 02:52 PM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
