Help with Dell PFS extractor
  • Udemzy
    • May 2017
    • 166
    • Guatemala
    Hello,I'm trying to extract dell BIOS from the firmware update from Dell support but each time i drag and drop the BIOS on Dell PFS extractor,I get an error message.
    Is there something I'm not doing well or i need to download something else before i can extract?
  • peste
    • Dec 2016
    • 13703
    • ROMANIA
    Re: Help with Dell PFS extractor
    try this..
    • Udemzy
      • May 2017
      • 166
      • Guatemala
      Originally posted by peste
      try this..
      Thanks,I'll try it and post the outcome here.
      • Udemzy
        • May 2017
        • 166
        • Guatemala
        I'm getting the same error message.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12372
          Upload your file here.
          ​https://www.badcaps.net/donate
            • 22035
            PFS Extractor 4.9 will do it.
            Thanks to Plato Mavropoulos for all the great software https://github.com/platomav
            • stars.4u
              stars.4u commented
              Editing a comment
              thanx bro.
          • Udemzy
            • May 2017
            • 166
            • Guatemala
            Thanks i really appreciate,it work fine.
            thanks to everyone that contributed,i appreciate for taking out time to comment.
            • ali.nb66
              • Nov 2016
              • 14
              • iran
              hi bro
              I am facing this error
                • 22035
                Originally posted by ali.nb66
                hi bro
                Its a different type,it will not extract using PFS extractor.
                Firstly you can extract a rom file by using the command line
                Alienware_m15_R2_m17_R2_1.16.1.EXE /writeromfile
                The rom will be written,then it needs editing to the correct size. You can use AMI_PFAT_EXTRACT software to remove the PFAT header,it will not remove the end part (footer) so it will need further editing with a hex editor. It isn`t a full bios image,it is only a bios update !
                • siroos_tz
                  • Feb 2014
                  • 121
                  • the UK
                  • Adebeebs
                    • Feb 2018
                    • 7
                    • Nigeria
                    please where do i get the extracted file?
                    • lapfix
                      • Mar 2020
                      • 2765
                      • my workshop
                      https://www.badcaps.net/forum/showpo...95&postcount=6
                      • Adebeebs
                        • Feb 2018
                        • 7
                        • Nigeria
                        this is what i am getting?
                        my first time using it
                        • lapfix
                          • Mar 2020
                          • 2765
                          • my workshop
                          YOU FIND THE EXTRACTED FILE AT THE SAME FOLDER OF Dell PFS extractor
                          Or if you want make a folder , put the dell exe and Dell PFS extractor in , than drag and drop the exe at Dell PFS extractor exe you will get the extracted files
                          • almirsilvestre
                            • Jun 2020
                            • 44
                            • Brasil
                            Thank you so much
                            Help me to bring my notebook alive again
                            • cdwayne foremost
                              • Mar 2015
                              • 22
                              • jamaica
                              i am loving it,works fine for me...
                              • EduarDOOX8
                                • Jan 2020
                                • 6
                                • Poland
                                I have a problem. I got message . . Done! But no file is created. I was searched for it manually, nothing. I changed folder, i changed bios, i changed extractor. Every time i got Done! But no file is created. Whats the problem? I searched that python is needed so i installed it but nothing changed
                                • lapfix
                                  • Mar 2020
                                  • 2765
                                  • my workshop
                                  Make a folder that contain bios + pfs extractor and try
                                  https://www.youtube.com/watch?v=nZ3gRlI0bvw&t=71s
                                  • EduarDOOX8
                                    • Jan 2020
                                    • 6
                                    • Poland
                                    Same story, changing partition with one folder including both files same story, running as administrator same story, changing names of bios files same story
                                    Is Windows 10 Home a problem, maybe that should be a pro version?
                                    I tried extractor from here and from labone site
                                      • 22035
                                      post a link to the bios you`re trying to extract
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • volinakis
                                        GUIDE TO USE DELL PFS EXTRACTOR or other extractors from BiosUtilities (my way)
                                        by volinakis
                                        1. Download BIOSUtilities (thanks to platomav) and move folder "BiosUtilities" to Desktop
                                        https://github.com/platomav/BIOSUtilities
                                        2. Install python 3.11.0 or higher (both versions for 32bit and 64bit)
                                        3. Download Dell bios update from Dell site (in my example bios update for Dell Latitude 3420) and move it to "BiosUtilities" from Desktop.
                                        4. RENAME update exe WHITOUT SPACES AND DOTS! In my example "Latitude_3420_Latitude_3520_1.37.0.exe" to "Latitude_3420_Latitude_3520_1_37_0.exe"...
                                        08-31-2024, 06:53 AM
                                      • zandatsu07
                                        Dell PFS Update Extractor extracted multiple files
                                        by zandatsu07
                                        I'm using dell pfs update extractor but it extracted multiple files instead of 1 bin file, what am i doing wrong here?
                                        My PC
                                        Dell Optiplex 7050 Micro...
                                        04-10-2024, 07:58 PM
                                      • brimley
                                        Extract BIOS from legacy DELL 1764 flash.exe
                                        by brimley
                                        Hi All,
                                        I just bought an old Dell Inspiron 1764 to put Linux on, but
                                        before doing that I thought I'd update the BIOS from windows using
                                        DELL's suggested file FLASHME_v103_Win_1194_4M_1764A13.exe.
                                        (https://www.dell.com/support/home/en...n-1764/drivers)
                                        This failed and bricked my laptop and this model doesn't seem to have any usb boot type recovery options.
                                        So now I'm trying to flash it myself using a CH341A BIOS USB Programmer
                                        but can't find any way to get the BIOS image out of the exe file....
                                        01-11-2022, 05:32 PM
                                      • Akhlz001
                                        by Akhlz001
                                        09-20-2025, 07:15 PM
