Lenovo Legion Pro NM-D562 Rev. 3.0
  • layad
    • Nov 2011
    • 244
    #61
    oh ok i will
    • twonk9098
      • Aug 2018
      • 69
      • United Kingdom
      #62
      Is anybody able to either remove the password from my attached bios file or supply a bios with the correct serial number and no password to replace mine?
      I have a Lenovo Legion 5 15ACH6H, Ryzen 7 with RTX 3070 GPU.
      My serial number is PF3D0S7W
      FACTORY id JVHFC1
      Many thanks
      • volinakis
        • Jan 2021
        • 2738
        • N/A
        #63
        FACTORY id JVHFC1
        Many thanks
        try
        • twonk9098
          • Aug 2018
          • 69
          • United Kingdom
          #64
          wow, thank you. Does this have my serial number?
          • A1yn88
            • Mar 2014
            • 112
            • Romania
            #65
            Hello. Can anybody help me with the BIOS. Starts but no video.
            NM-D562 rev 3.0
            SN:PF37943K
            • danito
              • Jun 2016
              • 968
              • Romania
              #66
              NM-D562 rev 3.0
              SN:PF37943K
              try
              • A1yn88
                • Mar 2014
                • 112
                • Romania
                #67
                Originally posted by danito
                try
                It's working. Thank you !!!
                • danito
                  • Jun 2016
                  • 968
                  • Romania
                  #68
                  with pleasure
                  • trepachka
                    • Oct 2022
                    • 429
                    Hello, I have this Lenovo Legion 5 17ACH6H computer with no power. I replaced the EC chip and the computer starts now but no post. When I push the power button, the keyboard lights up briefly, both fans begin to spin, the cpu and gpu get considerably warm but no post.
                    I suspect corrupted bios. Could someone, please take a look at the bin file and fix it? Thank you.
                    Legion 5 17ACH6H
                    S/N: PF3BW709
                    MTM: 82JY009DUS
                    • peste
                      • Dec 2016
                      • 12868
                      • ROMANIA
                      #70
                      Legion 5 17ACH6H
                      S/N: PF3BW709
                      MTM: 82JY009DUS
                      after the change did you rewrite the I/O chip???what chip is it??
                      • trepachka
                        • Oct 2022
                        • 429
                        It was a chip I purchased online. The chip was removed from another similar computer model. I soldered it onto the motherboard.
                        • peste
                          • Dec 2016
                          • 12868
                          • ROMANIA
                          #72
                          try post #5 and see what happens..
                          https://www.badcaps.net/forum/troubl...st#post1752856
                          • trepachka
                            • Oct 2022
                            • 429
                            I applied the file in post 5 and am getting the same results. No changes. I wonder if the EC chip I installed is also corrupted. All voltages are present. I can see both the cpu and gpu heating up under IR camera.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              #74
                              Heu guys, long time no post !
                              i'm with the same model above nm.d562 board on the bench , and need to flash the it8176FN that is altough a 56KB file , atention that its not the 192EC file , that IT is flashed via the main bios once its updated "! so if someone have the correct file for UI22 , i apreciate if someone can send me that file .
                              thk in advance
                              • peste
                                • Dec 2016
                                • 12868
                                • ROMANIA
                                #75
                                thk in advance
                                read the rules..https://www.badcaps.net/forum/troubl...before-posting
                                post the S/N, the original bios of the laptop, the motherboard model, the full name and model of the laptop,
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  #76
                                  peste well the board code is there , look carefully , it say nm.d562 . i can't give any 56kb file , since the IT8176fn was burned , so therefore i can't read dump , but due to past issues with does legions ,i'm common with the problem , therefore i asked directly for the EC file for the IT8176FN that is a 56kb file , alltough i didn't gave SEria number because there is no 56kb file on the main file , cheked the HEX from many versions with that ITxxxxFN and no main bios has the file itself .
                                  but if that bother you .
                                  legion 5 15ach6h SN pf312xcg ...
                                  • peste
                                    • Dec 2016
                                    • 12868
                                    • ROMANIA
                                    #77
                                    try without writing it, see what happens.. leave the laptop on longer...
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      #78
                                      i thing you missunderstood me , but thk anyway .
                                      i sayed i can't give you the original 56kb file because the IT itself is toasted ! and flashing via KEYboard line will flash always the IT8176FN and not the IT8227e ! so i replaced the burned ITE , but now i need a 56KB DUMP , doesnt bother in sending the 192kb or 256kb because the info is not in this EC .
                                      well i would be here asking for the dump if i wouldn't have made all possible test and tryings , i work on this for over 15 years
                                      • nicoleb2004
                                        • Jun 2019
                                        • ROMANIA
                                        #79
                                        hello,
                                        i need bios for lenovo legion 5 pro 16ACH6H
                                        S/N PF38JLK4
                                        MotherBoard NM D562 REV 3.0
                                        I attached the old bios
                                        Thank You!
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11809
                                          #80
                                          Originally posted by nicoleb2004
                                          hello,
                                          S/N PF38JLK4
                                          Thank You!
                                          Legion 5 Pro-16ACH6H Laptop (Lenovo) - Type 82JQ
                                            LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                            This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                            09-12-2024, 02:30 PM
                                            Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 05:00 AM
                                            Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            LENOVO Legion T730 Legion i9-9900K Specification for Upgrade or Repair
                                            This specification for the LENOVO Legion T730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T730 boardview and Legion T730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
