Lenovo Legion Pro NM-D562 Rev. 3.0
  • hoaca388
    Badcaps
    • Jan 2022
    • 12340
    #41
    Originally posted by notrespond
    hello, can help me rebuild old bios
    Lenovo Legion Pro 5 16ACH6H 82JQ
    Problem display but every 1 minutes or a few second turn off again
    Board NM-D562 rev 1.0
    SN : PF303KYN
    biod old attached
    MMM
    • notrespond
      • Apr 2024
      • 70
      • ID
      #42
      Originally posted by hoaca388
      MMM
      thanks sir, its work
      • Andriy00
        • Aug 2023
        • Ukraine
        #43
        Legion 5 pro 16ACH6
        s/n: PF3BCA2C
        NM-D601 rev 1.0
        does not turn on, the power button lights up, the keyboard does not light up, does not heat up, all the voltages are there except for the CPU GPU RAM, I think the problem is in the bios​
        • Good2Know
          • 23
          Hi.
          Could someone help me with a working bios, please ?
          I am learning bios stuff step by step but have no experience to edit or repair anything bios related.
          Symptoms:
          Only white power led, no fan, no display, cpu/gpu are heating up, all main voltages present.
          Legion 5 Pro 16ACH6H
          S/N:PF36JSEP
          NM-D562 Rev: 2.0
          MO: PF9XB1809284
          MTM: 82JQ009SEG
          Thank you for your time and effort.
          Orig. bios attached.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12340
            #45
            Originally posted by Andriy00
            Legion 5 pro 16ACH6
            s/n: PF3BCA2C
            NM-D601 rev 1.0
            Laptop Legion 5 Pro-16ACH6 (Lenovo) - Loại 82JS
            • hoaca388
              Badcaps
              • Jan 2022
              • 12340
              #46
              Originally posted by Good2Know
              Hi.
              Symptoms:
              S/N:PF36JSEP
              NM-D562 Rev: 2.0
              MO: PF9XB1809284
              MTM: 82JQ009SEG
              Laptop Legion 5 Pro-16ACH6H (Lenovo) - Loại 82JQ
              • Good2Know
                • 23
                Thank you very much, unfortunately exactly same issues as described.
                Maybe small bios has also issues (???)
                • miscac
                  • Feb 2018
                  • 7
                  • indonesia
                  #48
                  Legion 5 pro 16ACH6
                  s/n: PF3BCA2C
                  NM-D601 rev 1.0
                  has it been solved sir?
                  i have same problem.
                  • Good2Know
                    • 23
                    Removed EC bios in order to make a backup and then tried to power laptop on without it (out of curiosity) .
                    Now i turns on (!) and i can excess bios etc. but sometimes pressing power gives me only power led, nothing more.
                    Can someone please tell me how to proceed (?)
                    EC bios attached.
                    • FrozenHaxor
                      • Jun 2015
                      • 266
                      • Poland
                      #50
                      EC bios attached.
                      What do you mean exactly? You have erased the KBC then powered it on without any contents? On some Lenovo boards there will be an automatic KBC programming taking place using EC region from main bios flash, but I only know of that on brand new KBC chips that have certain factory flag still set which goes away upon first programming.
                      The board will absolutely not start in any way shape or form and certainly not allow you to enter BIOS settings with an empty KBC chip.
                      • Good2Know
                        • 23
                        I did not start the laptop with an empty ec/kbc bios chip. It was off the board because i made a backup (just in case).
                        Then i startet the laptop (without the ec bios chip on board) to see what would happen.
                        Isn't UU137 the ec bios chip ?
                        • FrozenHaxor
                          • Jun 2015
                          • 266
                          • Poland
                          #52
                          No, the KBC itself is programmable with embedded flash.
                          • tectronlab
                            • May 2021
                            • Perú
                            #53
                            hello,
                            Problem only keyboard backlight, no display
                            Board NM-D562 rev 3.0
                            SN : PF3A5BYB
                            Old bios attached​
                            • volinakis
                              • Jan 2021
                              • 2874
                              • N/A
                              #54
                              Originally posted by tectronlab
                              hello,
                              SN : PF3A5BYB
                              Old bios attached​
                              try
                              • Andriy00
                                • Aug 2023
                                • Ukraine
                                #55
                                Hello, I did not solve the problem myself, I sent it to the service, and there they said that the processor died, they changed it and it came back to life
                                • FrozenHaxor
                                  • Jun 2015
                                  • 266
                                  • Poland
                                  #56
                                  Very doubtful they did that, inspect the board. Lenovo are notoriously hard to do this on due to the black epoxy underfill used on BGA components. BGA desolering in this case usually results in delaminated board and ripped pads along with lifted traces.
                                  • layad
                                    • Nov 2011
                                    • 244
                                    #57
                                    hi
                                    legion 5 pro 16ach6h
                                    serial number: pf3mc26b
                                    nm-d562 rev 2
                                    believe bios is bad no display
                                    if you can help me with fixing it pls
                                      • 21973
                                      Post the motherboard model number https://www.badcaps.net/forum/troubl...before-posting
                                      • layad
                                        • Nov 2011
                                        • 244
                                        #59
                                        posted thanks
                                        • peste
                                          • 13656
                                          • ROMANIA
                                          #60
                                          Originally posted by layad
                                          posted thanks
                                          read post #35...
                                            LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                            This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                            09-12-2024, 02:30 PM
                                            Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:00 AM
                                            Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            LENOVO Legion T730 Legion i9-9900K Specification for Upgrade or Repair
                                            This specification for the LENOVO Legion T730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T730 boardview and Legion T730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
