Lenovo Legion Pro NM-D562 Rev. 3.0
  • isa198585
    • Feb 2020
    • 71
    • austria
    #141
    The BIOS from post 5 worked for me, however, I should mention that it didn't work the first time I turned it on. I forgot to turn off the device, and after 2-3 hours, it turned on by itself
    • kesmeseker
      • Jan 2015
      • 121
      • turkey
      #142
      hi.guys need help legion 5 pro no display, fan spin(on &off) & keyboards light. power light on.
      board no: NM-D562 rev: 3.0​
      s/nPF382EDK
      • peste
        • 13656
        • ROMANIA
        #143
        s/nPF382EDK
        post full name and model,type.etc..
        • kesmeseker
          • Jan 2015
          • 121
          • turkey
          #144
          lenovo legion 5 pro 16ach6h
          82jq
          s/nPF382EDK​
          • peste
            • 13656
            • ROMANIA
            #145
            82jq
            s/nPF382EDK
            you have everything you need at post #5...
            https://www.badcaps.net/forum/troubl...h-bios-request
            • kesmeseker
              • Jan 2015
              • 121
              • turkey
              #146
              not working .black screen.
              • rjsoft9
                • Aug 2018
                • 22
                • India
                #147
                someone help me with this issu ,Laptop turn off randomly every 1 min or 2min,
                some times all works good for 5 min turn off again
                Old bios attached
                Legion 5 Pro 16ACH6H
                S/N:PF37W74D​
                • peste
                  • 13656
                  • ROMANIA
                  #148
                  Old bios attached
                  S/N:PF37W74D
                  see post 145
                  • rjsoft9
                    • Aug 2018
                    • 22
                    • India
                    #149
                    Originally posted by peste
                    see post 145
                    No Display, fan spinng power light on.
                    • T-PDF
                      FeedBack_M13
                      • Mar 2025
                      • France
                      #150
                      Hey guys, i'm curently trying to repair the laptop of my uncle, here is the deal, when plugged : a short press will do nothing, but a long one does (2-3s),--> keyboard turns on for 5 secs after de click then turns off, -->Power button led stays yellowish and nothing on the screen and for the fans, it depends but most of the time, no fans.
                      So i'm guessing a bios fault but i'm not sure, haven't check the voltages yet.
                      Also when plugged : Orange led on the charging port and Legion logo on as well. (even after overnight recharge)
                      Specs :
                      Bios Chip Name : winbond 74M12JWSIQ 2137
                      Laptop name : Legion 5 Pro-16ACH6H Laptop (Lenovo) - Type 82JQ
                      S/N : PF3AQ5K2
                      MotherBoard : NM-D562 rev: 3.0
                      AMD Ryzen 7 5800H 16 Go SSD 1 To 16" LED QHD 165 Hz NVIDIA GeForce RTX 3070 8 Go Wi-Fi AX/Bluetooth Windows 10 Famille 64 bits
                      i've tried to reflash the bios with an CH341B, but nothing seems to work, i've even tried a bios from this forum (that matched the Motherboard rev: 3.0) and still the same results.
                      If some one could send me an trusted .bin, i'll try and get back to you. Otherwise i'll inspect my motherboard in details.
                      CPU and GPU are getting warm when charging.
                      Any help would be much appricated, thx in advance.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12340
                        #151
                        Specs :
                        S/N : PF3AQ5K2
                        Find hardware issue.
                        • Biostechnology
                          • Jun 2022
                          • 16
                          • India
                          #152
                          Originally posted by hoaca388
                          MMM
                          hello, can help me rebuild it8176f-56a ec kbc bin
                          Lenovo Legion Pro 5 16ACH6H 82Ju
                          my Problem is that keyboard not working, i am also replaced it8176fn-56a new one and ec progamming file form main bios (method uuite). someone help this regrading
                          Board NM-D562 rev 1.0
                          SN : p531kb0n
                          • Biostechnology
                            • Jun 2022
                            • 16
                            • India
                            #153
                            Originally posted by highpulse
                            Heu guys, long time no post !
                            i'm with the same model above nm.d562 board on the bench , and need to flash the it8176FN that is altough a 56KB file , atention that its not the 192EC file , that IT is flashed via the main bios once its updated "! so if someone have the correct file for UI22 , i apreciate if someone can send me that file .
                            thk in advance
                            hare the file
                            lets try
                            • madjid911
                              • 412
                              • France
                              #154
                              Hello, can you redo my original bios please, the laptop starts but does not display anything on the screen, I tried externally either, changed the ram either, I tried post 41 for the bios but the result remains the same.
                              I'm sorry I don't have the label on the laptop cover, so I don't know the serial number, the motherboard is NM-D562 REV 1
                              • PetrN2O
                                • Aug 2024
                                • 10
                                • Israel
                                #155
                                Please help fix the BIOS. There's no display (no image), the fans are spinning, and the keyboard backlight is on. GPU and CPU resistances are normal, and all voltages are present.
                                Model: Lenovo Legion 5 Pro 16ACH6H
                                Motherboard: NM-D562 Rev: 3.0
                                Product ID: 82JQ00R0IV
                                Serial Number (S/N): PF3848TQ
                                Part Number (PN): 5B21B90026​
                                • danito
                                  • Jun 2016
                                  • 1101
                                  #156
                                  original + dmi
                                  • Hamza1995
                                    • Sep 2022
                                    • 48
                                    • Algérie
                                    #157
                                    PLZ HELP ME NO AFFICHAGE
                                    Model: Lenovo Legion 5 Pro 15ACH6H
                                    Motherboard:HY660 HY661 HY561 HY572 HY56C HY57K NM-D562 REV 3.0
                                    Serial Number (S/N): PF3B5NM0
                                    Part Number (PN): 5B21C22565​
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12340
                                      #158
                                      Legion 5-15ACH6H Laptop (Lenovo) - Type 82JU
                                      • Hamza1995
                                        • Sep 2022
                                        • 48
                                        • Algérie
                                        #159
                                        Same problem
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12340
                                          #160
                                          Same problem
                                          Then you don't have to worry about bios anymore.
                                            LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                            This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                            09-12-2024, 02:30 PM
                                            Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:00 AM
                                            Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            LENOVO Legion T730 Legion i9-9900K Specification for Upgrade or Repair
                                            This specification for the LENOVO Legion T730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T730 boardview and Legion T730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
