BIOS for Asus UX330UAR REV 2.1
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Laptop has no display tried checking th chip select pin 1 of bios has no good reading on oscillo.
    Hope someone can provid Ill atttached my bin also..
  • hoaca388
    Badcaps
    • Jan 2022
    • 12403
    Re: BIOS for Asus UX330UAR REV 2.1
    Find all the stickers and QR codes on the main board to identify the exact device model.
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      PN: 60NB0CW0-MBA020
      BACK COVR : X330U
      No serials
      • DanielDacko
        • Mar 2015
        • 328
        • Macedonia
        This should be fine, backup and try.
        I don't provide help for people using CH341A and a clip.
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          Same problem sir.. Hope someone can check the bios if it's bad?
            • 22085
            Originally posted by kalilinux25
            PN: 60NB0CW0-MBA020
            BACK COVR : X330U
            No serials
            are you sure there`s no barcode sticker
            • kalilinux25
              • Mar 2018
              • 2093
              • ZAMBOANGA SIBUGAY
              It have sir
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                  • 22085
                  The bios at post #4 by daniel is ok,its an F1 Asus service bios ,look for other problems
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    Thanks sir Ill just post a other thread..
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • grimacelord
                      by grimacelord
                      07-10-2025, 02:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
