ASUS X515EA - X415EA Rev 6.0 Bios Bin
  • theused13
    • Mar 2022
    • 3
    • Philippines
    #81
    Pls unlock file
  • shiyab
    • Sep 2023
    • 1592
    • india
    #82
    Originally posted by theused13
    Pls unlock file
    post snid
    • gyro10
      • Sep 2020
      • 24
      • Philippines
      #83
      Originally posted by hoaca388
      Re: ASUS X515EA - X415EA Rev 6.0 Bios Bin
      Try
      i try this bios and its work but the issue is my keyboard not work. and i try buy new one keyboard. but same issue... pls help me to my problem
      this is my back up bios
      • hoaca388
        Badcaps
        • Jan 2022
        • 12267
        #84
        Serial number ?
        • gyro10
          • Sep 2020
          • 24
          • Philippines
          #85
          Serial number ?
          THIS
          • gyro10
            • Sep 2020
            • 24
            • Philippines
            #86
            Serial number ?
            IM SORRY im wrong to upload bios back u hahah
            this one is the original bios
            im so sorry for give me my Fault
            • hoaca388
              Badcaps
              • Jan 2022
              • 12267
              #87
              THIS
              You MUST:
              • Read BIOS guides, methods, resources and tools
              • Try the method at BIOS guides, methods, resources and tools before requesting help
              • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
              • Use search function in case someone already answered your request
              • Post under a related thread if it exists
              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
              • Name your thread with make, full model numbers and request
              • Provide a BIOS/EC dump if possible
              • Attach files directly to your post instead of linking to external websites
              • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
              • exerion5000
                Bios Needed For Asus X515EA Pcb X415EA R2.0
                by exerion5000
                Asus X515EA_No Power_GD25B127D@SOIC8.rar
                Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                02-17-2025, 01:34 PM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
