ASUS X515EA - X415EA Rev 6.0 Bios Bin
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Hello, I've attempted to use this BIOS, and while the laptop boots, my M.2 SSD isn't recognized in the BIOS menu. Could someone please assist me in clear this bios?
Laptop Model : V5200J ( X515EA)
Motherboard model : X415EA R 6.0
SN : MCN0CV199137516
I'd greatly appreciate any assistance. Thanks in advanced!!
Attached FilesComment
https://www.badcaps.net/forum/troubl...se#post3516245Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
try popst #6...
https://www.badcaps.net/forum/troubl...se#post3516245Comment
This is the BIOS that was on my laptop. I would appreciate it if you could decode it (forgive my bad EnglishAttached FilesComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
UnlockedAttached Files
Funciona el archivo "work" pero me pide bitlocker porque dice q no tiene arranque seguro (y si lo tieen activado asi qe supongo q son las llaves) se pueden pasar las llaves del bios viejo, el dañado.. a el nuevo funcionando? Gracias
The "work" file works, but it asks me for Bitlocker because it says it doesn't have secure boot (and it does have it enabled, so I assume it's the keys). Can the keys be transferred from the old, damaged BIOS to the new, working one?
in English please...
post the contents of the bios chip even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hy guys. Can you please help me unlock this bios dump.
ASus: X515EA-EJ1413
SN: R4N0CV143803175Attached FilesComment
Type the laptop serial number, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by exerion5000Asus X515EA_No Power_GD25B127D@SOIC8.rar
Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...-
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
