ASUS X515EA - X415EA Rev 6.0 Bios Bin
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptions -
Hello, I've attempted to use this BIOS, and while the laptop boots, my M.2 SSD isn't recognized in the BIOS menu. Could someone please assist me in clear this bios?
Laptop Model : V5200J ( X515EA)
Motherboard model : X415EA R 6.0
SN : MCN0CV199137516
I'd greatly appreciate any assistance. Thanks in advanced!!
Attached FilesPremium supporters get full download access and other benefits.
try popst #6...
https://www.badcaps.net/forum/troubl...se#post3516245If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
https://www.badcaps.net/settings/subscriptionsComment
Hi, already tested with bios from that post #6 But it's still the same (no storage devices present).try popst #6...
https://www.badcaps.net/forum/troubl...se#post3516245Comment
Hello, my laptop's BIOS has a password and I'm looking for its BIOS file. I tried another BIOS, but my laptop's keyboard didn't light up, and my laptop has a touch screen and it says R565ea-uh31t on the back of the case. Thank you for your help
This is the BIOS that was on my laptop. I would appreciate it if you could decode it (forgive my bad EnglishAttached FilesPremium supporters get full download access and other benefits.
UnlockedAttached FilesPremium supporters get full download access and other benefits.
Funciona el archivo "work" pero me pide bitlocker porque dice q no tiene arranque seguro (y si lo tieen activado asi qe supongo q son las llaves) se pueden pasar las llaves del bios viejo, el dañado.. a el nuevo funcionando? Gracias
The "work" file works, but it asks me for Bitlocker because it says it doesn't have secure boot (and it does have it enabled, so I assume it's the keys). Can the keys be transferred from the old, damaged BIOS to the new, working one?
in English please...
post S/N, full name and model, motherboard model, etc.Funciona el archivo "work" pero me pide bitlocker porque dice q no tiene arranque seguro (y si lo tieen activado asi qe supongo q son las llaves) se pueden pasar las llaves del bios viejo, el dañado.. a el nuevo funcionando? Gracias
post the contents of the bios chip even if it is corrupted..If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
Hy guys. Can you please help me unlock this bios dump.
ASus: X515EA-EJ1413
SN: R4N0CV143803175Attached FilesPremium supporters get full download access and other benefits.
tryAttached FilesPremium supporters get full download access and other benefits.
Type the laptop serial number, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
Hello, good afternoon. Could you help me with my BIOS? After updating, it doesn't display an image.
Motherboard model
x415EA
R2.0
SN: M3N0CV16N36212DAttached FilesPremium supporters get full download access and other benefits.
try
Give a responseAttached FilesPremium supporters get full download access and other benefits.
by exerion5000Asus X515EA_No Power_GD25B127D@SOIC8.rar
Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...-
Channel: BIOS Requests ONLY!
by piratiHello everyone,
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by ronaldopdiasI’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
- Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
- BIOS file downloaded directly from the official ASUS support page.
- Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
Issue:
The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
Because FlashBack didn’t work, I:- Removed the BIOS SPI IC from
- Loading...
