ASUS X515EA - X415EA Rev 6.0 Bios Bin
  • hoaca388
    Badcaps
    • Jan 2022
    • 11700
    #61
    Originally posted by salawayon
    got one X415E with password:
    infos:
    board - X415EA R2
    SN - M7N0CV11M43428D
    thanks...
    Unlocked
    • salawayon
      • Nov 2012
      • 568
      • philippines
      #62
      Originally posted by hoaca388
      Unlocked
      working.. Thank you very much for the help...
      • vanlong22686
        • Sep 2024
        • Vịt nam
        #63
        Re: ASUS X515EA - X415EA Rev 6.0 Bios Bin
        Try
        thank ok 100%
        • KoPhyoe
          • Jul 2021
          • 24
          • Myanmar
          #64
          Try
          Hello, I've attempted to use this BIOS, and while the laptop boots, my M.2 SSD isn't recognized in the BIOS menu. Could someone please assist me in clear this bios?
          Laptop Model : V5200J ( X515EA)
          Motherboard model : X415EA R 6.0
          SN : MCN0CV199137516
          I'd greatly appreciate any assistance. Thanks in advanced!!​
          • peste
            • Dec 2016
            • 12742
            • ROMANIA
            #65
            try popst #6...
            https://www.badcaps.net/forum/troubl...se#post3516245
            • KoPhyoe
              • Jul 2021
              • 24
              • Myanmar
              #66
              Originally posted by peste
              Hi, already tested with bios from that post #6 But it's still the same (no storage devices present).
              • Hamid_kianii
                • May 2025
                • 5
                • Iran
                #67
                Hello, my laptop's BIOS has a password and I'm looking for its BIOS file. I tried another BIOS, but my laptop's keyboard didn't light up, and my laptop has a touch screen and it says R565ea-uh31t on the back of the case. Thank you for your help
                • Hamid_kianii
                  • May 2025
                  • 5
                  • Iran
                  #68
                  ​​​​​​This is the BIOS that was on my laptop. I would appreciate it if you could decode it (forgive my bad English
                  • Hamid_kianii
                    • May 2025
                    • 5
                    • Iran
                    #69
                    Unlocked
                    Can you help me too?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11700
                      #70
                      You forgot the serial number, this is a forum rule.
                      • Hamid_kianii
                        • May 2025
                        • 5
                        • Iran
                        #71
                        SN:M9N0CV143628387
                        Model: R565EA-UH31T
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11700
                          #72
                          SN:M9N0CV143628387
                          Model: R565EA-UH31T
                          Unlocked
                          • Hamid_kianii
                            • May 2025
                            • 5
                            • Iran
                            #73
                            Unlocked
                            It worked!!!thanks😍
                            • baltaszar
                              • Feb 2014
                              • 19
                              • mexico
                              #74
                              Funciona el archivo "work" pero me pide bitlocker porque dice q no tiene arranque seguro (y si lo tieen activado asi qe supongo q son las llaves) se pueden pasar las llaves del bios viejo, el dañado.. a el nuevo funcionando? Gracias
                              The "work" file works, but it asks me for Bitlocker because it says it doesn't have secure boot (and it does have it enabled, so I assume it's the keys). Can the keys be transferred from the old, damaged BIOS to the new, working one?
                              in English please...
                              • peste
                                • Dec 2016
                                • 12742
                                • ROMANIA
                                #75
                                post S/N, full name and model, motherboard model, etc.
                                post the contents of the bios chip even if it is corrupted..
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • exerion5000
                                  Bios Needed For Asus X515EA Pcb X415EA R2.0
                                  by exerion5000
                                  Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                  Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                  02-17-2025, 01:34 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
                                • throwaway327
                                  by throwaway327
                                  Model No: RC72LA
                                  Serial No: SBNVKD001014459
                                  06-18-2025, 05:52 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
