Dell xps l322x bios + ec ???
  • quic307
    • Jun 2015
    • 255
    • Greece
    Hi all you techs,
    I need bios and ec for DELL XPS l322x DAD13AMBCD1 REV_D1.
    I found in other post but doesn't work.
    I attached my old bios and ec.
    Can someone check the pin out if it's correct? (it8518g) just in case ...
    DAD13AMBCD1 REVD
    KB_pins=30
    PD0=18 PD1=16 PD2=17 PD3=15 PD4=11 PD5=10 PD6=13 PD7=12 BUSY=24 STB=9 AFD=7 INIT=5 SLIN=8 KSI4=4 KSI5=6
    Thank you in advance.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    Re: Dell xps l322x bios + ec ???
    Originally posted by quic307
    hi all you techs,
    i need bios and ec for dell xps l322x dad13ambcd1 rev_d1.
    Dad13ambcd1 revd
    kb_pins=30
    pd0=18 pd1=16 pd2=17 pd3=15 pd4=11 pd5=10 pd6=13 pd7=12 busy=24 stb=9 afd=7 init=5 slin=8 ksi4=4 ksi5=6
    thank you in advance.
    xps 13 l322x
    • quic307
      • Jun 2015
      • 255
      • Greece
      Originally posted by hoaca388
      xps 13 l322x
      Thank you for the answer, but the EC doesn't veryfing to the KB controller and it's different with the original.
      Can you check it?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12278
        I have never seen the contents of such an EC. If you notice, it's the Descriptor and ME region of the bios, it's not the EC content.
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • jhanra
          by jhanra
          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
          11-02-2024, 04:19 AM
        • gizaha
          by gizaha
          02-13-2024, 07:18 AM
