Dell xps l322x bios + ec ???
  • quic307
    • Jun 2015
    • 259
    • Greece
    Hi all you techs,
    I need bios and ec for DELL XPS l322x DAD13AMBCD1 REV_D1.
    I found in other post but doesn't work.
    I attached my old bios and ec.
    Can someone check the pin out if it's correct? (it8518g) just in case ...
    DAD13AMBCD1 REVD
    KB_pins=30
    PD0=18 PD1=16 PD2=17 PD3=15 PD4=11 PD5=10 PD6=13 PD7=12 BUSY=24 STB=9 AFD=7 INIT=5 SLIN=8 KSI4=4 KSI5=6
    Thank you in advance.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Dell xps l322x bios + ec ???
    Originally posted by quic307
    hi all you techs,
    i need bios and ec for dell xps l322x dad13ambcd1 rev_d1.
    Dad13ambcd1 revd
    kb_pins=30
    pd0=18 pd1=16 pd2=17 pd3=15 pd4=11 pd5=10 pd6=13 pd7=12 busy=24 stb=9 afd=7 init=5 slin=8 ksi4=4 ksi5=6
    thank you in advance.
    xps 13 l322x
    • quic307
      • Jun 2015
      • 259
      • Greece
      Originally posted by hoaca388
      xps 13 l322x
      Thank you for the answer, but the EC doesn't veryfing to the KB controller and it's different with the original.
      Can you check it?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        I have never seen the contents of such an EC. If you notice, it's the Descriptor and ME region of the bios, it's not the EC content.
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • Sathsul
          Dell Latitude 5431 issues with dumping bios
          by Sathsul
          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
          10-28-2025, 07:49 AM
