Go to dell support and enter the service tag. At the right side of the page under Quick links click on View product specs .Look carefully at the specs, it is Non vPro . ME vPro firmware is larger in size than consumer firmware. Look at some of the 32MB dumps from this thread with Flash Image tool, see if they are vPro or not. Look at some of the 8+16MB dumps as well, (the 8 + 16MB files must be joined together first or FIT/MFIT won`t open it) and see if they are Non vPro. Once you know which bios you need look for those that are confirmed working, with clean ME firmware.
Dell Latitude 5400 bios request
Go to dell support and enter the service tag. At the right side of the page under Quick links click on View product specs .Look carefully at the specs, it is Non vPro . ME vPro firmware is larger in size than consumer firmware. Look at some of the 32MB dumps from this thread with Flash Image tool, see if they are vPro or not. Look at some of the 8+16MB dumps as well, (the 8 + 16MB files must be joined together first or FIT/MFIT won`t open it) and see if they are Non vPro. Once you know which bios you need look for those that are confirmed working, with clean ME firmware.Comment
Good day to all!
Could someone help to delete this bios password ?
Dell 5400
Service Tag : CX0H353
Mainboard : EDC41 LA-G891P Rev: 1.0 (A00)
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Post more 16MB chip.Comment
Unlocked
Could you help me repair this BIOS? I saved both bios, but from the description and size it is not vpro.
uc5 8mb - backup-8mb-lat5400-2rscy63.bin
uc6 16mb - backup-16mb-lat5400-2rscy63.bin
TAG: 2rscy63
Thank'sAttached FilesComment
Service Tag: 2RSCY63Attached Files
Hi
Dell LATITUDE 5400
Service Tag : B3WN633
Thank You
Hello Badcaps Members
i have this lap comming from another repair center every thing good exept bios chip not existe ( removed )
this Model EDC41 LA G891P REV 1.0 have 4 vendors TMT-GCE-HSB-TRIPOD and those dumps not compatible with all
Dell latitude 5400
Service Tag : JFQ3L33
Board No : EDC41 LA G891P REV 1.0
VENDOR : TMT
here exemple for each vendor in this model some vendors have 8mb+16mb+32
some vendors with only 32mb
Hi Can you also help me with computrace?
Service tag - GPDM433
mother board EDC41 LA-G891P REV 1.0 (A00).
Winboond 25Q256JVEQAttached FilesComment
obs: me vpro
Please test and give feedback.Attached FilesComment
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
by DavidChuncoHi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
- Receive help from Dell Support (it is out of warranty).
- Disconnect machine from AC power and battery overnight.
- BIOS recovery process
- Connected external display via HDMI
- Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...-
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
- Loading...
