Dell Latitude 5400 bios request
    Originally posted by corona100 View Post
    here exemple for each vendor in this model some vendors have 8mb+16mb+32
    some vendors with only 32mb
    Go to dell support and enter the service tag. At the right side of the page under Quick links click on View product specs .Look carefully at the specs, it is Non vPro . ME vPro firmware is larger in size than consumer firmware. Look at some of the 32MB dumps from this thread with Flash Image tool, see if they are vPro or not. Look at some of the 8+16MB dumps as well, (the 8 + 16MB files must be joined together first or FIT/MFIT won`t open it) and see if they are Non vPro. Once you know which bios you need look for those that are confirmed working, with clean ME firmware.
      still need dump this didn't help thank's any way fo help
        Good day to all!
        Could someone help to delete this bios password ?
        Dell 5400
        Service Tag : CX0H353
        Mainboard : EDC41 LA-G891P Rev: 1.0 (A00)
          Originally posted by Gastrarbaiter View Post
          Good day to all!
          Dell 5400
          Post more 16MB chip.
          Become a Badcaps supporter
          Thanks to all supporters.
              Unlocked
                Hoaca388, thank you very much! Everything works fine! Дай Боже вам здоров"я!
                  Could you help me repair this BIOS? I saved both bios, but from the description and size it is not vpro.
                  uc5 8mb - backup-8mb-lat5400-2rscy63.bin
                  uc6 16mb - backup-16mb-lat5400-2rscy63.bin
                  TAG: 2rscy63
                  Thank's
                    TAG: 2rscy63
                    Thank's
                    Latitude 5400
                    Service Tag: 2RSCY63
                      Originally posted by hoaca388 View Post
                      Latitude 5400
                      Thanks for sending it, I recorded the two files, but there was no video.
                      The keyboard blinked a bit and it wouldn't turn on.
                      Is there another repair file?
                        try and feedback
                          Originally posted by LBTT1121 View Post
                          try and feedback
                          Thanks for the file, still no success.
                          the board doesn't turn on.
                          it has 3.3v, 5v, 7.8v coils, but it doesn't turn on and no LEDs light up.
                            LBTT1121 hoaca388
                            I noticed that this notebook has an SPI (XMC 25HQ128 16mb) on an auxiliary board and the voltages +3.3V_ALW, +5V_ALW when the board has the flat cable connected to the USH.
                            Does this SPI need to be recorded?
                              Hi
                              Dell LATITUDE 5400
                              Service Tag : B3WN633
                              Thank You
                                Originally posted by raulitiu View Post
                                Hi
                                Dell LATITUDE 5400
                                Thank You
                                try and feedback
                                  try and feedback
                                  thank you, it works fine
                                    Hello Badcaps Members
                                    i have this lap comming from another repair center every thing good exept bios chip not existe ( removed )
                                    this Model EDC41 LA G891P REV 1.0 have 4 vendors TMT-GCE-HSB-TRIPOD and those dumps not compatible with all
                                    Dell latitude 5400
                                    Service Tag : JFQ3L33
                                    Board No : EDC41 LA G891P REV 1.0
                                    VENDOR : TMT
                                    case not yet solved
                                      Hi Can you also help me with computrace?
                                      Service tag - GPDM433
                                      mother board EDC41 LA-G891P REV 1.0 (A00).
                                      Winboond 25Q256JVEQ
                                        Winboond 25Q256JVEQ
                                        follow bios with clean Me region and BIOS Manufacture Mode.
                                        obs: me vpro
                                        Please test and give feedback.
                                          case not yet solved
                                          According to the description in your notebook's documentation, the service tag is a no-vpro.
                                          According to your motherboard diagram, the no-vpro processor uses two bios:
                                          uc5 8mb
                                          uc6 16mb
                                          You need to join the two files to assemble the biosrom.bin.
