Please need unlock 830 g8
  • Fighter
    Veteran Member
    • Jul 2017
    • 40
    • Pakistan
    #61
    Re: Please need unlock 830 g8
    Here is U367 Chip of front side for Endpoint issue thanx....i'll check password and endpoint after programming this chip thanx .....
    Last edited by SMDFlea; 03-26-2023, 02:47 PM. Reason: Deleted attachment due to low server space, March 2023
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      #62
      Here's the other chip.
      all donations are welcome,
      • Fighter
        Veteran Member
        • Jul 2017
        • 40
        • Pakistan
        #63
        Password gone works perfect ....Endpoint security issue clear ....But there is another issue which came after Bios Programming.......System is Booting into Manufacture Programming Mode....solution please
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          #64
          You need to use a tool called BCU to make the programming mode locked, you can search and figure out how to use it.
          • Fighter
            Veteran Member
            • Jul 2017
            • 40
            • Pakistan
            #65
            ok sir thanx i'll try ....Stay Blessed
            • gsmtechno
              • Oct 2014
              • 24
              • Tunisie
              #66
              need to unlock this bin
              Thanks in advance.
              Last edited by SMDFlea; 03-26-2023, 02:49 PM. Reason: Deleted attachment due to low server space, March 2023
              • hardware1
                • Sep 2021
                • 2949
                • N/A
                #67
                Thanks in advance.
                Here's your Unlocked file, if the password still there upload your another chip (EC Chip), it could be 16MB or 32MB.
                • volinakis
                  • Jan 2021
                  • 2874
                  • N/A
                  #68
                  Enter Bios Setup, you have a tab called "Set Machine Unique Data" , you have stickers on the back of bottom cover with Feature Byte, Built ID, etc, write them and save, then boot in windows and use BCU under cmd BiosConfigUtilityx64.exe /get:1.txt, modify MPM from *Unlock to *Lock, save as 2.txt in Docs (will not let you to save under BCU folder) copy 2.txt in BCU folder and use BiosConfigUtilityx64.exe /set:2.txt , restart.
                  • Grim13
                    • Dec 2018
                    • 7
                    • romania
                    #69
                    Hp elitebook x360 830 g8 bios password
                    Hello i have an hp x360 830 g8 with password on bios can someone unlock it?
                    i have read the Ec file
                    • hardware1
                      • Sep 2021
                      • 2949
                      • N/A
                      #70
                      Re: Hp elitebook x360 830 g8 bios password
                      Here's your Unlocked EC file, in the first boot go to bios menu and disable security options (Default). If the password still present, upload the Main chip.
                      • Grim13
                        • Dec 2018
                        • 7
                        • romania
                        #71
                        Works great.Thank you
                        • MAZMAZ23
                          • Jan 2023
                          • 33
                          • ALGER
                          #72
                          i have read the Ec file :Noob:
                          Last edited by SMDFlea; 03-26-2023, 02:50 PM. Reason: Deleted attachment due to low server space, March 2023
                          • miansh621
                            Banned
                            • May 2022
                            • 133
                            • pakistan
                            #73
                            Originally posted by mazmaz23
                            hello i have an hp x360 830 g8 with password on bios can someone unlock it?
                            I have read the ec file
                            feedback
                            • tracker1
                              • Jul 2017
                              • 118
                              • romania
                              #74
                              Need help with HP EliteBook 830 G8 Bios Password
                              I copy all 3 bios cips on mainbaord.
                              • hardware1
                                • Sep 2021
                                • 2949
                                • N/A
                                #75
                                Here are you Unlocked files, program the both files together.
                                In the first boot go to Bios Menu and disable security options (Default).
                                • hunglaptop1102
                                  • Dec 2018
                                  • 82
                                  • viet nam
                                  #76
                                  • lapfix
                                    • Mar 2020
                                    • 2765
                                    • my workshop
                                    #77
                                    Give feedback
                                    • tracker1
                                      • Jul 2017
                                      • 118
                                      • romania
                                      #78
                                      Thank you!!! Password is gone!!!
                                      • slavikkalacun
                                        • Apr 2017
                                        • 8
                                        • Ukraine
                                        #79
                                        Good afternoon, could you please explain or share a utility that would remove passwords from HP laptops with an EC flash drive size of 32 MB
                                        • lapfix
                                          • Mar 2020
                                          • 2765
                                          • my workshop
                                          #80
                                          upload your dump , and compare between the 2 files with HXD tool
                                          • qsenc
                                            ThinkBook 14/15 G2 ARE bios unlock
                                            by qsenc
                                            Hi guys,
                                            i have looked everywhere for a way to unlock this bios but seems only G2 ITL has a way to be unlocked ( witch i thought is the same) , but not this model. Also i have looked for a hardware way for unlock.
                                            Did anyone had success to unlock this model?
                                            Thank you
                                            ThinkBook 15 G2 ARE Laptop - Type 20VG
                                            Serial Number MP1X30S7
                                            Machine Type Model 20VG0008UK...
                                            09-17-2025, 11:59 PM
                                          • Syseng
                                            Lenovo P14s Gen 5 SVP unlock
                                            by Syseng
                                            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                            06-22-2025, 07:44 AM
                                          • remizbushka
                                            Dell inspirion 5775 bios "Unlock Setup fail"
                                            by remizbushka
                                            Hi sirs. please help
                                            Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                            After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                            What I did:
                                            I read the bios dump.
                                            Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                            03-24-2025, 09:07 AM
                                          • rabsonnjala
                                            fujitsu w26361-W1881-Z2-02-36 BIOS UNLOCK
                                            by rabsonnjala
                                            Hallo team i need your assistance to unlock the above BIOS. i couldnt find dumps on the internt. Please find the attached image for extra info. the fujitsu unlock tool aint working as well . thanks...
                                            10-13-2025, 11:12 AM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
