work perfect, thanks you sir.
Please need unlock 830 g8
Hi, I already replaced the original BIOS with the attached file, now I can enter the BIOS conf, but now mi laptop shows the " HP Endpoint Controller Problem" message, then I done all the process on
https://www.badcaps.net/forum/troubl...security-error
but the message is still showing and then it reboots when you hit the ok button.
Can you help me?
Thank'sComment
Can you help me?
Thank'sComment
Thank you SMDFlea
backup from main BIOS
tryComment
Thank you shiyab !
Greetings, can you help me with my HP 830 g8 password problem and Endopoint Controller Security serial number 5cg1374ZBT board 6050A3217501? I really appreciate the help.Attached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
Hi everyone, can you help me with my HP 830 g8 password problem and Endopoint Controller Security serial number 5CG1443H8T ? I really appreciate the help.Comment
Please help unlock this 830 G8 sn 5CG225A1MT, thanks!Attached FilesComment
Unlocked
Attached Files↵
Hi everyone , posting here the 2 bios file fom hp elitebook 830 g8 Bios wit no password in case someone needs a clean bios, mainly the 256 mb should be fine but just in case i posted the 8 mb secondary chip alsoAttached FilesComment
i need unlock Hp Elite Book 830 G8 password bios
this have 32mb main and ecAttached FilesComment
- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
SN 5CG1374ZBT
CORVETTE-6050A3217501-MB-A01
bios password
You MUST:- Read BIOS guides, methods, resources and tools
Attached Files↵
by qsencHi guys,
i have looked everywhere for a way to unlock this bios but seems only G2 ITL has a way to be unlocked ( witch i thought is the same) , but not this model. Also i have looked for a hardware way for unlock.
Did anyone had success to unlock this model?
Thank you
ThinkBook 15 G2 ARE Laptop - Type 20VG
Serial Number MP1X30S7
Machine Type Model 20VG0008UK...-
Channel: BIOS Requests ONLY!
by SysengThis sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...-
by remizbushkaHi sirs. please help
Dell Inspiron 5775 bios locked "Unlock Setup fail"
After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
What I did:
I read the bios dump.
Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....-
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
by Syavko1Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? -
- Loading...
