Hallo team i need your assistance to unlock the above BIOS. i couldnt find dumps on the internt. Please find the attached image for extra info. the fujitsu unlock tool aint working as well . thanks
fujitsu w26361-W1881-Z2-02-36 BIOS UNLOCK
Tags: None
Don't post pictures unless asked...write with the keyboard...No one wastes time enlarging pictures, turning them, or using a magnifying glass to see numbers or letters..
it makes our work easier, not yours..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Channel: BIOS Requests ONLY!
BIOS access (F2) and Boot Menu (F12) are no longer possible โ the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
by macabookHello everyone,
Iโm currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโm at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโs a full breakdown:
๐งฉ Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
07-24-2025, 02:17 PM -
I need a BIOS dump file for my Fujitsu LIFEBOOK AH47/J laptop.
Motherboard model: DAFH6BMB6A0
The system BIOS got corrupted and now the laptop powers on but does not boot.
I already tried the official Fujitsu support site, but the downloadable BIOS is only in .exe format and does not contain the raw .bin file needed for programming the BIOS chip directly with a programmer (CH341A).
If anyone has a working BIOS dump (.bin) for this model, please share it.
Thanks in advance!...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
