Need bios for dell xps 17 9710
  • sourcebf
    • Jul 2016
    • 433
    • N/A
    HI FOR ALL
    MY OROGINAL BIOS IS CORRUPTED, CAN YOU HELP ME PLEASE
    XPS 17 9710
    SERVICE TAG 5N91HL3
    THANKS IN ADVANCE
  • hoaca388
    Badcaps
    • Jan 2022
    • 12269
    Re: Need bios for dell xps 17 9710
    Try.
    • sourcebf
      • Jul 2016
      • 433
      • N/A
      Originally posted by hoaca388
      Try.
      thanks for your help but with this dump laptop is completly dead
      • hoaca388
        Badcaps
        • Jan 2022
        • 12269
        I just changed the file upload.
        • sourcebf
          • Jul 2016
          • 433
          • N/A
          Dump 100% working
          • MagnificentMagnolia
            • Dec 2022
            Hey sourcebf,
            I have precisely the same problem, my XPS 9710 BIOS is toasted. I checked your service tag on Dell's website and it's the same GPU/CPU configuration as mine. So I'd like to give your fixed version a try. I'm curious now how did you flash the BIOS to the machine? I located the BIOS flash chip on the motherboard. Did you use a programmer like CH341A clipped to the chip, or is there some other secret method / header to reflash the BIOS? I'd love to hear from you!
            • djdhusy
              • Jul 2024
              • 34
              • Malaysia
              Hi To all,
              here i attached the backup file (Stuck on Dell logo) Please help me to get a clean bios
              Model- Dell Precision 5760
              Serial - 3F0DZ93
            • trepachka
              • Oct 2022
              • 446
              Hello, I have this XPS 9710 that refuses to charge due to "The Ownership Date" field being empty in BIOS. Basically, it doesn't even want to recognize the charger until the battery charge percentage drops to 55% or lower. I tried to reflash the BIOS by using a bin file from a different thread but the computer does a repeating pattern: keeps flashing DELL logo, no boot. If I revert to the original BIOS, computer works just fine but not charging.
              Could you, please fix the bios file so that either the ownership date is already populated or perhaps I can go into the manufacturing mode and change it myself. Thanks.
              Model: XPS 9710
              Service Tag#: DW51LG3
              • trepachka
                • Oct 2022
                • 446
                I downloaded several bios files from different websites with mixed results. However, none of them work. The only bin file that works is the one I posted but again no ownership date. If someone can help me out and either fill out the ownership date or fix my bin file, that would be great.
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Loli Popu
                  DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                  by Loli Popu
                  Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                  12-13-2024, 08:29 AM
                • wwbielsko
                  Dell latitude 5320 corrupted bios repair
                  by wwbielsko
                  I got corrupted bios bin file, which way is correct to repair.
                  File puts errors on Me Analyzer and cannot open in FIT.
                  To open in FIT I made:
                  1. Extract MFS and EFS using MEAnalyzer from other bios file with the same parameters
                  2. put it in HxD to my file
                  3. MEAnalyzer shows 1 error after that
                  4. file opens in FIT
                  and:
                  A:
                  1. extract current dell bios on website
                  2. put System BIOS with BiosGuard v1.30.0.bin using FIT
                  3. MEAnalyzer OK no errors
                  (this version shows only logo at bootup - freezeing)...
                  04-23-2024, 06:16 PM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • jhanra
                  by jhanra
                  in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                  11-02-2024, 04:19 AM
