HP Elitebook 840 G6 bios password
  • emrahbktsss
    • Aug 2017
    • 16
    • turkey
    #221
    Originally posted by shiyab
    hi try flash 16 mb
    works great thank you
    • aladin2l
      • Sep 2020
      • 27
      • phillipines
      #222
      help unlock bios password need to install new os because ssd defective
      model : hp elitebook 840-g6
      sn: 5CG031061PC
      advance thanks for the help
        SMDFlea commented
        Editing a comment
        Post moved to 840 G6 thread topic........
    • hoaca388
      Badcaps
      • Jan 2022
      • 11744
      #223
      sn: 5CG031061PC
      Unlocked
      • aladin2l
        • Sep 2020
        • 27
        • phillipines
        #224
        Originally posted by hoaca388
        Unlocked
        thank you for this
        • DUCKMAN
          • Jan 2024
          • 13
          • VIETNAM
          #225
          please unlock biospassword .tks
          SN# 5CG9525SXG
          ProdID 7KK23UT#ABA
          • lapfix
            • Mar 2020
            • 2729
            • my workshop
            #226
            SN# 5CG9525SXG
            ProdID 7KK23UT#ABA
            First boot load bios factory defaults, save and exit and then at the next boot disable security options
            You must fill your DMI manually.​
            • DUCKMAN
              • Jan 2024
              • 13
              • VIETNAM
              #227
              thanks. the password in the 16mb file. i unlocked it myself
              • Genova
                • Jan 2020
                • 116
                • FRANCE
                #228
                Hello guys,
                Need help to recover bios. Laptop start, blows fast, black screen and stop, again, again... Sometimes turn on with caps lock only turned on (no flashing) and no activity.
                Serial Number : 5CG0103K35
                Product Number : 4WG20AV
                Description : HP EliteBook 840/846 G6​
                • Stefan Steff
                  • Mar 2024
                  • 255
                  • Romania
                  #229
                  Originally posted by Genova
                  Hello guys,
                  This bios saved me many times...maybe u need to use BCU to put back the right DMI info
                  • Genova
                    • Jan 2020
                    • 116
                    • FRANCE
                    #230
                    Hello, so I flashed it this morning but it's very difficult to turn it on. After several attempts, it finally rebooted, but runs a continuous bios recovery by stopping and restarting.
                    • Blaze Tech
                      Learner
                      • 205
                      • Ghana
                      #231
                      try
                      • Genova
                        • Jan 2020
                        • 116
                        • FRANCE
                        #232
                        Hello, the pc doesn't boot, the power LED flashes orange and white, the shift key flashes white for a few seconds, goes out, then flashes white again for a few seconds, in a loop. The PC tries to start up but shuts down just as quickly.
                        • Genova
                          • Jan 2020
                          • 116
                          • FRANCE
                          #233
                          I also tried your bios again this morning with another program. The pc did several startups, with recovery of its identity from the Embedded Controller due to data mismatch. After several restart corruption IME firmware so continue to complete the full recovery process on the Intel ME... after several restart the laptop seems to be behaving normally again. I go to the bios and reset the security settings and save. Laptop restart aks to confirm, etc...Everything seems to be back to normal.
                          I reconnect the cmos battery, the battery, and back cover the pc doesn't boot anymore.
                          no LEDs anywhere. I decide to remove the bottom cover and the pc boots up, but nothing appears on the screen.
                          I disconnect the battery, discharge the PC for 30 seconds, then connect the charger and press the power button: the PC starts up the fan blows hard but nothing is displayed during several seconds and finally the PC shuts down.
                          Orange LED on charging port, no longer possible to switch on laptop.
                          • TECHO TN
                            • Jan 2024
                            • 57
                            • algeria
                            #234
                            solder the bios chip well then its will turn on again
                            • Genova
                              • Jan 2020
                              • 116
                              • FRANCE
                              #235
                              Thanks for answering, but I didn't unsolder the chip.I only work with clamps or pin probe.
                              • TECHO TN
                                • Jan 2024
                                • 57
                                • algeria
                                #236
                                Reflash it again
                                Its better to do it by desoldering and soldering
                                Choose a working bios then rewrite your laptop information using BCU
                                If you don't know how i will help you
                                • Genova
                                  • Jan 2020
                                  • 116
                                  • FRANCE
                                  #237
                                  I've already wasted too much time on this laptop. It gave me hope by behaving normally, but then it started to malfunction again.
                                  I'll try again later, but thanks to those who replied to my post.​
                                  • iceboy2010
                                    • Mar 2023
                                    • romania
                                    #238
                                    Serial Number : 5CG016CLH4
                                    Product Number : 4WG30AV
                                    hello, can someone help me?​i have bios pass.
                                    • Stefan Steff
                                      • Mar 2024
                                      • 255
                                      • Romania
                                      #239
                                      Leave the 32Mb Main chip alone and write only the 16 Mb chip.
                                      • TECHO TN
                                        • Jan 2024
                                        • 57
                                        • algeria
                                        #240
                                        try
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                        • BlackVisor
                                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                          by BlackVisor
                                          RedmiBook Pro 1542022 6800H
                                          SKU: TM2113-39463
                                          Model Number: RMA2204-AB
                                          CMIIT ID: 2022AP1835
                                          SN: 39463/22WD01355
                                          BIOS version: RMARB5B0P1010 20230628
                                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                          01-14-2024, 06:35 AM
