HP BIOS unlock tool
  • dopin13
    • Nov 2011
    • 7
    • Bulgaria
    #1181
    Re: HP BIOS unlock tool
    any help with bios password
    HP ELITEBOOK 1050 G1
    DA0XW1MBAI1 REV: I
    • Bsolution
      Banned
      • Oct 2021
      • 73
      • punjab
      #1182
      hp elitebook 1050 g1
      da0xw1mbai1 rev: I
      post 2nd bios backup
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #1183
        DA0XW1MBAI1 REV: I
        Here you are (gotov si gradski )
        Become a Badcaps supporter
        Thanks to all supporters.​
        • dopin13
          • Nov 2011
          • 7
          • Bulgaria
          #1184
          2nd bios backup
          • dualtrace
            • Jan 2022
            • 9
            For those wishing to try desoldering / soldering their flash chips, here is some research I did into the sort of soldering temperatures these chips are ok with.
            Code:
            Key temps and times for e.g. Winbond 128 SPI:
            85°C - max operating temp of SPI chip
            150°C - max storage temp of SPI chip
            ???  - SPI chip max soldering temp "compliant with JEDEC Standard J-STD-20C"
            138°C - Melting point of 42/58 tin/bismuth solder eg 'Mechanic V4B45'
            183°C - Melting point of 63/37 lead/tin solder
            190°C - Melting point of 60/40 standard lead/tin solder
            225°C - JEDEC Standard J-STD-20C lowest peak reflow temperature
            230°C - Melting point of standard lead-free solder
            260°C - JEDEC highest peak reflow temperature
            Max soldering time at max temp, 30-40s
            I was going to try the 42/58 tin/bismuth solder myself, for a wide safety margin.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1226
              • France
              #1186
              Code:
              https://youtu.be/CbguNgQO5hc?t=661
              • dualtrace
                • Jan 2022
                • 9
                Excellent info thanks.
                I had wondered what would happen if one left a bit of chip quik on the pads - but sounds like that pitfall can easy happen with using the bismuth solder too.
                Noticed when practicing, the hot air needs to blow much hotter than the listed melting points. Especially when there's big areas of copper track / nearby heat sinkery. I was only just managing to cleanly desolder WSON8 6X5's off scrap boards at around 320 deg measured by a thermocouple touching the chip, sometimes even higher.
                On the bright side despite the high temp, I've had SPI chips that have got that hot & still seem to respond ok on a ch341a.
                • kristaps123
                  • Jan 2022
                  • 3
                  • Latvia
                  #1188
                  Hi, Thanks to this forum and great people here i have managed to unlock my bios HP 820 G2! Thanks to forum developer and all hard working guys.
                  Have a nice day!!
                  • RethoricalCheese
                    • Mar 2013
                    • 1518
                    • Estonia
                    #1189
                    Just forget the temperatures. I applied reverse voltage onto one wson8 winbond chip for 15 minutes. It actually melted a hole on top of that package so chip die was visible. After that it worked fine, I got all data from it, written to another chip and no errors.
                    Hot air station set to 420C mostly. Not saying its the correct temperature. Cheap stations tend to show semi-random numbers anyway
                    • dopin13
                      • Nov 2011
                      • 7
                      • Bulgaria
                      #1190
                      Special thanks to Vesko356!
                      Bios works fine - unlocked !
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #1191
                        You're welcome. Have fun!
                        • mepttbblk
                          • Jan 2022
                          • 33
                          • Ukraine
                          #1192
                          Hello, please help me with the HP 830 G7 bios password, thanks in advance.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #1193
                            • mepttbblk
                              • Jan 2022
                              • 33
                              • Ukraine
                              #1194
                              Thank you
                              Works fine
                              • anubys
                                • Dec 2021
                                • 13
                                • Hungary
                                #1195
                                attempted to reset BIOS admin password for HP Probook 650 G2, and HPUnlocker tool was successfully executed, but after bin file created by HPUnlocker was written into BIOS chip, BIOS admin password is still there. BIOS SW level is N76 (latest).
                                Could SomeOne help to reset admin password? Please find original dumped BIOS bin with admin password, without any attempts with HPUnlocker.
                                Thanks in advance
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #1196
                                  Thanks in advance
                                  Unlocked:
                                  • anubys
                                    • Dec 2021
                                    • 13
                                    • Hungary
                                    #1197
                                    Unlocked:
                                    Looks beautiful, many thanks for the fast response and help!
                                    I suspected, that it should be different addresses to be cleared, then the ones cleared by HPUnlocker tool (most likely HPUnlocker is not prepared /yet/ to handle this BIOS SW level).
                                    Thanks again!
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #1198
                                      You're welcome
                                      Thanks again!
                                      The tool works great, just your case is "the exception that proves the rule",
                                      in other words, it is different from the standard ones for which the Unlocker is intended for, which's why the tool fails to do its job.
                                      • anubys
                                        • Dec 2021
                                        • 13
                                        • Hungary
                                        #1199
                                        You're welcome
                                        Sure, thanks for clarifying!
                                        • Vesko356
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #1200
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            Yesterday, 05:12 AM
                                          • mohamedbalwe
                                            BIOS FOR DS-7204HQHI OR UNLOCK PASS FOR THIS FILE
                                            by mohamedbalwe
                                            hello everyone
                                            i need bios dvr DS-7204HQHI
                                            motherboard code 80303-p rev 2.2
                                            The attached file is lock pass...
                                            07-14-2025, 06:02 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
