HP BIOS unlock tool
  • kros
    • Oct 2017
    • 18
    • IE
    #1201
    Re: HP BIOS unlock tool
    Hello, please help me with the HP EliteBook 8770w bios password, thanks in advance.
      • 22192
      Have you tried the tools at post #1
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #1203
        Did you try the tool?
        Edit: @SMDFlea - I did not notice your comment, you've posted while I was processing the bios.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • kros
          • Oct 2017
          • 18
          • IE
          #1204
          Yes, I tried this tool and there is no password anymore, but the functions in bios are not active and I can not now use the boot to upload windows 10 with a pen because all functions in bios are not active, I cannot enter them , maybe the tool did something wrong and these functions are inactive and cannot be entered ??
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #1205
            You can't enter the bios with F10, or your can but all parameters are grayed out, and you can't change any?
            Try to restore bios defaults.
            • kros
              • Oct 2017
              • 18
              • IE
              #1206
              Yes I can go to bios now but all parameters are greyed out and I can't change them
              • andrew25
                • Feb 2016
                • 224
                • Malawi
                #1207
                can anybody help me unlock 840 g6 bios password please... attached locked files
                • Mr. Neo
                  • Jan 2022
                  • Bangladesh
                  #1208
                  Originally posted by itsmagic1
                  The tool works great for a HP 830 G5. It unlocks my Administration Password!
                  Thanx a lot!
                  I want to add LT4211 4G module to this HP Elitebook 830 G5. Do you think I can do that after using this tool? Will this remove the whitelist from BIOS?
                  • Mr. Neo
                    • Jan 2022
                    • Bangladesh
                    #1209
                    Hello Mate,
                    HP ELITEBOOK 830 G5
                    BIOS: sp136471 (https://ftp.hp.com/pub/softpaq/sp136...0/sp136471.exe)
                    Version: 01.18.01 Rev.A
                    Release date: Dec 17, 2021
                    Windows 11 Pro 21H2
                    I have added a WWAN as below:
                    HP lt4211 Gobi 4G Module
                    but, BIOS showing error 703. So far I understand it has something to do with the whitelist. Please, please, please help.
                    Best Regards / Mr. Neo
                      • 22192
                      No it does not remove any whitelist. Try over at bios-mods.com
                      • doa379
                        • Aug 2021
                        • 19
                        • US
                        #1211
                        Is it possible to do a verification of the password data in the BIOS dump? If I load the dump into a hex editor then at which part of the file should I expect to see a password or a cleared password? Are cleared passwords simply marked as 0 at said section of the dump? Essentially what is the algorithm that the tool uses to clear passwords? Knowing this will be helpful in working with dumps from a safety standpoint.
                        • diskettenfett
                          • Jan 2022
                          Hello!
                          I have a HP Probook 650 G4 which sadly has a BIOS administrator password, so I cannot enter BIOS setup. I desoldered the W25Q256 flash from the board, read it (3 times, consistently), modified it via hpunlocker.exe and flashed it back.
                          System starts up, but it is still asking for an administrator password sadly. Any ideas what I might have done wrong or what I might have missed?
                          Files attached are original BIOS, modified BIOS, screenshot from system info.
                          Many thanks in advance!
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #1213
                            Originally posted by diskettenfett
                            Hello!
                            Upload your 16MB chip bios dump.
                            • diskettenfett
                              • Jan 2022
                              Oh, sorry, seems I did the process on the wrong bios IC? Or do both need to be modified?
                              I attached both original bios dumps. Had to find and desolder the other one... Thanks for your kind support!
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #1215
                                You're welcome.
                                Program 16MB chip only:
                                • diskettenfett
                                  • Jan 2022
                                  You're welcome.
                                  So I better revert the 25Q256 back to its original state, I guess?
                                  I can't thank you enough! If this works out, I owe you one. Send me your Paypal address via PM, I'll send you some beer (or at least so you can buy some )
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #1217
                                    No, leave it as is for now, just flash the 16MB chip with the new file.
                                    • diskettenfett
                                      • Jan 2022
                                      Worked perfectly! Many thanks again!
                                      • doa379
                                        • Aug 2021
                                        • 19
                                        • US
                                        #1219
                                        I have a HP 840 G1 with a BIOS Administrator password and a User password. I downloaded the firmware to a file but after applying the patch and flashing the firmware back, the Administrator password has removed but the user is still there. As such I am only able to login as Guest user. Although the Guest user does not allow me to clear any other users. The tool has not cleared any BIOS users with password. It would be helpful to know what does the tool actually do and is there a way to clear out users as well as their corresponding passwords from the BIOS?
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #1220
                                          Yes there is a way to do this. Upload your dump here.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
