HP BIOS unlock tool
  • danito
    • Jun 2016
    • 899
    #521
    Re: HP BIOS unlock tool
    hi,
    HP 820g4 i5-7200u
    try with HPUnlocker and caplock & numlk led x5 and fan max.
    • Nico Latour
      Banned
      • Sep 2019
      • 52
      • france
      #522
      7e gen no succes by unlock with the hp unlocker
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        #523
        Originally posted by danito
        hi,
        HP 820g4 i5-7200u
        Try this and let me know.
        • danito
          • Jun 2016
          • 899
          #524
          working
          thx
          • RethoricalCheese
            • Mar 2013
            • 1518
            • Estonia
            #525
            This will be fixed in the next version.
            • SRO2
              • Sep 2018
              • 44
              • FRANCE
              #526
              Thank you very much RethoricalCheese! I was able to use your program successfully on 650 G2, 8470P and 840 G3
              On the 840 G3 there were 2 chips, a Winbond and an MXIC. I first patched the Winbond dump but there was still the password, then I patched the MXIC dump and it was OK.
              Thank you very much for developing and making this program available!
              • silencer51
                • 5
                • Greece
                #527
                Just wanted to give a huge thanks to the OP for this utility. Successfully removed bios password from an Elitebook 820 G2.
                Bios chip is a Macronix 25L12873F which is not technically supported by flashrom, yet reading and writing both worked by using the MX25L12835F/MX25L12845E/MX25L12865E option.
                • silencer51
                  • 5
                  • Greece
                  #528
                  The Winbond chip is the EC ROM (size=2048MB), I suggest flashing back the original, you could have messed up the embedded controller firmware (although if the laptop works, I guess its fine).
                  • delgado
                    • Oct 2020
                    • 8
                    • DE
                    #529
                    I used an old version of the 341A flasher that did not correctly identified the chip (only 2MB were read out of the chip). I put the dump into the HPunlocker and then I reflashed this 2MB unocked file into the bios chip. Of course now my notebook is not starting anymore. Only LED'S flashing. My Notebook is a HP 840 G2 i5200U.
                    Is it possible to fix the bios chip by reflashing an unlocked version of the bios from someone else?
                    Please advise.
                    If so, can someone send me the unlocked version of the 840 G2 i5200?
                    • peste
                      • 12729
                      • ROMANIA
                      #530
                      Please advise.
                      post the motherboard model ..
                      • delgado
                        • Oct 2020
                        • 8
                        • DE
                        #531
                        it is a HP 840 G2 i5 5200U. It has 2 chips. See attachments.
                        • peste
                          • 12729
                          • ROMANIA
                          #532
                          motherboard model, look for something on the board of this shape 6050a2637901-mb-a02, written on the board with paint ..
                          • delgado
                            • Oct 2020
                            • 8
                            • DE
                            #533
                            A02 Board
                            • delgado
                              • Oct 2020
                              • 8
                              • DE
                              #534
                              ...i did not remove the cover as I used a SOIC clip to flash. Do I need to remove the cover to find the MB number?
                              • alin.cocos
                                • Nov 2020
                                #535
                                First check this site to see if your HP is supported for the great tool Mazzif has made.
                                http://mazzifsoftware.blogspot.com/p...os-unlock.html
                                If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
                                For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
                                When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
                                Just program the new file on your bios IC.
                                This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
                                For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry:
                                Code:
                                Computer\HKEY_CLASSES_ROOT\*\shell\HPUnlocker\command
                                Then modify that string adding
                                Code:
                                "C:\*location-of-exe*\HPUnlocker.exe" "%1"
                                This way you just need to right click your locked file and select HPUnlocker.
                                If there are any issues, please do let me know so I can improve this tool.
                                Hi
                                I'm kind of new on this. I have a HP Zbook G3 with locked bios. I have a CH341A programmer (I just buy this) and when I start the tool it say Failed to execute script HPUnlocker. I run this on Windows 10 x64 from C:\ or D:\ (set compatibility mode to win 7).
                                Can you please help me to unlock my bios?
                                It's correct what I understand?
                                - read locked bios using CH341A programmer
                                - backup locked bios
                                - erase bios
                                - unlock bios using HP Unlocker
                                - flash bios using CH341A programmer tool
                                Thank you for your help
                                • peste
                                  • 12729
                                  • ROMANIA
                                  #536
                                  yes..remove the cover and read on the motherboard, do not use the clip to read or write the bios chip ... you may have errors..remove the bios chip from the motherboard before reading or writing it ..
                                  • delgado
                                    • Oct 2020
                                    • 8
                                    • DE
                                    #537
                                    thank you for assisting.
                                    I fixed the problem by using a different fashing programm and still using SOIC clip.
                                    My recommendation is:
                                    CH341 V 1.29 programmer does not work correctly
                                    ASProgrammer does not wirk correctly
                                    NeoProgrammer 2.1.0.19 is working!
                                    I used clean 840 G2 Bios dump from another website:
                                    https://www.laboneinside.com/hp-elit...0-g2-bios-bin/
                                    Everyting works fine now & PW is gone!
                                    Thank you.
                                    • delgado
                                      • Oct 2020
                                      • 8
                                      • DE
                                      #538
                                      my HP 840 G2 Notebook is working again but the bios management engine is not working. Any fix for that after flashing Bios from a different system?
                                      • peste
                                        • 12729
                                        • ROMANIA
                                        #539
                                        post the bios that works for your laptop
                                        • delgado
                                          • Oct 2020
                                          • 8
                                          • DE
                                          #540
                                          ...find it attached freshly dumped.
