bios for hp PROBOOK 455 G8
 Every donation made will go towards server fees and maintenance costs.Comment
 Thank you, i found the chip with the AS Programmer. But it seems like i cant read the chip via the clipper or do i make something wrong?Comment
 You used the wrong tool, with WSON chip you have to use this.
 https://shopee.vn/Bigdealsnice-Sop8-...2-4f563c2c4430↵
 https://www.badcaps.net/donateComment
 HP ProoBook 455 G8Mainboard
 DA0X9QMB8E0 Rev: E
 Hello can anybody repair this bios, please it turns on but there is no image on the screen, the fan is spinning at high speedAttached FilesComment
 Hello everyone. Can you please help me? I have a black screen, and the fan is running at full speed.
 Here are the details:
 HP PROBOOK 455 G8
 ProID: 1Y9H0AV
 SN: 5CD1303620
 RMN: HSN-Q31C-5
 DA0X9QMB8D0 Rev D
 I have attached the BIOS and EC files.
 Thanks in advance!
 hello guys . i have a machine , fun runs at max speed and there's no display.
 details
 HP pro book 455 G8
 S/N:5CD2064Y24
 pro ID: 1Y9H0AV
 DA0X9QMB8E0 rev:E
 attached are my filesComment
 try this one (main bios) and if it works write DMI with BCU. You'll find values on a label of bottom case or in your bios starting with hex adress: 107A730Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 ----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
 Hi, unlock bios please,
 HP Probook 455 G8 DA0X9QMB8E0 REV:E
 ProdID 1Y9H0AV
 sn: # 5CD2132DKQ
 dump EC_BIOSAttached FilesLast edited by warsztat; 02-24-2025, 04:22 AM.Comment
 UnlockedAttached Files↵
 Hello everyone, I have a problem with a hp 455 g8 computer which has a display problem. I have tried to program the SPI_ROM but the chip does not respond (certainly spoiled) and I have programmed the Ec_ROM, the computer no longer turns on, I have replaced the two SPI and EC chips with other chips from another identical motherboard and the fan runs strongly.
 The information on the computer is :
 SN: 5CD1303620
 Can you help me find a file that will make the motherboard work?Comment
 pleas help manufacturing mode
 HP PROBOOK 445 G8
 HSN-Q31C da0x9qmb8d0 revD
 prodID 3C3K6ES#UUW
 SN # 5CD1297W9ZAttached FilesComment
 Be more clear.pleas help manufacturing mode
 HP PROBOOK 445 G8
 prodID 3C3K6ES#UUW
 SN # 5CD1297W9Z↵
			by glovecapsHello,
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
 I have opened the laptop and identified the main BIOS chip...2 Photos-
							Channel: BIOS Requests ONLY!
			by oraganohey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
 So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
 i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...-
 10-17-2024, 02:53 AM
			by AkaBukaiHi there,
 I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
 The little LED on the power button is flashing slowly and nothing happen.
 This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
 So I decided to flash the BIOS using a cheap programmer.
 And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
 I also...
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
