Surface Pro 6 password
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: Surface Pro 6 password
can you please unlock this dump.
If i write ME region from my original backup BIN (which is locked) to a similar bios file from this Thread, touchscreen will work? i write a new randomly bios (unlocked) and is working fine but touchscreen doesn't work, even if i install newest drivers.
I appreciate if someone help me!Attached FilesComment
I appreciate if someone help me!Attached FilesLast edited by Vesko356; 04-09-2023, 02:58 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
I bought a surface pro 6 and it had a password. Could someone help me? I modified the dump but it is still not clean.Attached FilesComment
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
hi there, can someone help me to unlock this bios? mb: m1086841-003
it has bios password, thanksAttached FilesComment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
I NEED TO REMOVE Surface Pro 6 password BIOS DUMPAttached FilesComment
Re: Surface Pro 6
by me i had also no touch after use your bios file
has anybody solution
thanksComment
Re: Surface Pro 6
Read the rules before posting:
Surface Pro 6 Intel 8250u
s/n 069077684653
thx
logo appears for 2 seconds, off admin, please fix itAttached FilesComment
PLEASE unipassAttached FilesComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
surface pro 6 1796
m1086841-003
sn\ 012308791653
1796 128GB
need to unlouck uefi password plzAttached FilesLast edited by teto8485; 01-21-2024, 02:47 PM.Comment
You MUST post the serial number with EVERY bios request !!!
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
can any one help me to clear the issue
problem:- surface logo come then off.. itry another file..its working..but touch not working
i attached my old file..facingh issue logo coming then off
sutface pro 6 1796
serial no:- 006989390953
512GB i7 16GB M1796Attached FilesLast edited by nikhilchandran@1997; 02-14-2024, 12:31 AM.Comment
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by shadow666hello
i need surface book 3 dump bios
Model : 1899
MB : 1899_TOP
Rev 2.0
Serial : 037248401157
CPU :Core i7-1035G7
Dump Bios problem is no power
Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
Regard...-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
