Surface Pro 6 password
    Re: Surface Pro 6 password
    Originally posted by Smeek View Post
    bios password is gone, touchscreen doesn't work anymore and can't install drivers.
    I found a way to fix this issue with touchscreen. you need a USB recovery, from microsoft surface recovery, download the files and copy on USB stick. after that go an Surface tablet and go Recovery from USB. After this all driver are like new and working perfect.
    Yes, the problem with the touchscreen appears after unlocking.
    And yes, this is exactly the way to solve the matter, it is also mentioned at #31.
    Become a Badcaps supporter
    Thanks to all supporters.​
      can you please unlock this dump.
      If i write ME region from my original backup BIN (which is locked) to a similar bios file from this Thread, touchscreen will work? i write a new randomly bios (unlocked) and is working fine but touchscreen doesn't work, even if i install newest drivers.
      I appreciate if someone help me!
          Originally posted by Vesko356 View Post
          is working great
          Thank you!
            I bought a surface pro 6 and it had a password. Could someone help me? I modified the dump but it is still not clean.
              try..
                hi there, can someone help me to unlock this bios? mb: m1086841-003
                it has bios password, thanks
                    Thanks Vesko356, it works perfectly !!
                      Originally posted by peste View Post
                      try..
                      Thank you very much Peste, everything works fine, including the touch screen.
                      I take this opportunity to make a donation to the forum
                        ok, I'm glad I could help you and thank you for understanding the need for a donation..
                          I NEED TO REMOVE Surface Pro 6 password BIOS DUMP
                            Re: Surface Pro 6
                            by me i had also no touch after use your bios file
                            has anybody solution
                            thanks
                              Re: Surface Pro 6
                              thanks
                              You must post the serial number, full laptop model name and your original bios backup.
                              Read the rules before posting:
                                Surface Pro 6 Intel 8250u
                                s/n 069077684653
                                thx
                                logo appears for 2 seconds, off admin, please fix it
                                  PLEASE unipass
                                    Originally posted by sarltap View Post
                                    PLEASE unipass
                                    Serial number ?
                                    These are the rules from the forum.
                                      surface pro 6 1796
                                      m1086841-003
                                      sn\ 012308791653
                                      1796 128GB
                                      need to unlouck uefi password plz
                                        SMDFlea commented
                                        Editing a comment
                                        You MUST post the serial number with EVERY bios request !!!
                                        You MUST:
                                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                      #59
                                      Originally posted by teto8485 View Post
                                      surface pro 6 1796
                                      m1086841-003
                                      sn\ 012308791653
                                      1796 128GB
                                      Send to you
                                        can any one help me to clear the issue
                                        problem:- surface logo come then off.. itry another file..its working..but touch not working
                                        i attached my old file..facingh issue logo coming then off
                                        sutface pro 6 1796
                                        serial no:- 006989390953
                                        512GB i7 16GB M1796
