Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
It's always best that the device has the correct info, so I just moved your DMI from your dump file to the working BIOS from post #14.
Now you shouldn't face any problem.Attached Filesif you find these attachements useful please consider making a small donation to the site
This one is corrupted, I believe my dump corrupted this part but the other one (for V15 G2) worked perfectly! thanks!Comment
flash bios on lenovo ideapad 3 15ACL6
i'm new here, so i hope im correct here.
My lenovo ideapad 3 (Mainboard HS461&HS561&HS761 NM-521 REV2.0) is broken and i will try to flash the bios chip new. But my problem is, that i found only one chip called "winbond 74M12JWSIQ" is this the correct chip? Because normally all bios chips should be started with 25*** or i'm wrong?Comment
Re: flash bios on lenovo ideapad 3 15ACL6
Yes, it's the correct chip, (16MB-1.8V).Hello,
My lenovo ideapad 3 (Mainboard HS461&HS561&HS761 NM-521 REV2.0) is broken and i will try to flash the bios chip new. But my problem is, that i found only one chip called "winbond 74M12JWSIQ" is this the correct chip? Because normally all bios chips should be started with 25*** or i'm wrong?Attached Filesif you find these attachements useful please consider making a small donation to the site
lenovo ideapad 3 15ACL6 bios request
Hello i already tried all the tutorials to create the bios by my own and also all the bios files which are in this forum, but still have a blackscreen. So i hope someone can create the bios for me and i will try again.
Its a lenovo ideapad 3 15ACL6
MO: PF9XB153151
MTM: 82KU0034GE
Rev 2.0
Re: lenovo ideapad 3 15ACL6 bios request
Virgin BIOS with your DMI, try it.Hello i already tried all the tutorials to create the bios by my own and also all the bios files which are in this forum, but still have a blackscreen. So i hope someone can create the bios for me and i will try again.
MO: PF9XB153151
MTM: 82KU0034GE
Rev 2.0
thanks, but still not working.
Is maybe the chip broken, if i try to verify the chip then i get every time different memory address
HTML Code:Verify memory... Verification error on address: 00000296 Execution time: 00:00:00.033 Current programmer: CH341 19:53:11 Verify memory... Verification error on address: 000000AE Execution time: 00:00:00.031
Try NeoProgrammer V2.2.0.10 ---> https://www.badcaps.net/forum/showth...11#post1215111
Don't use a clip.
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hi! Will this work for my laptop, its a different type? If it does, where do I change the type and serial number?
IdeaPad 3-15ALC6
Type: 82ku
SN: PF2VDQ4T
MTM: 82KU003NUS
Mobo: HS461& HS561& HS761 NM-D521 2020-12-11 Rev:2.0
Thanks!Comment
Read post #20
I read literally every post, on every thread, that was even remotely relevant, which unfortunately, was hundreds. It got all jumbled up in my head.
Post 20 says to read post 4, the copyDMI guide. It also says to remove the header but it's unclear if I remove the header from the "oldbios" AND the "newbios."
The "newbios" is the bin file made after unpacking the Phoenix TDK file, mentioned in a different thread on this site? Does it matter that my original bios ("oldbios") is 16,384 kb and the "newbios" is 8,192 Kb? attached both.
Sorry if these sound like stupid questions. Thanks for your help!Attached Filesif you find these attachements useful please consider making a small donation to the site
Reading all related posts is not enough, you must try to understand all the information in that posts otherwise you just read some text which obviously is not very fruitful as you (and I) can see.
Slow down - first of all old bios is needed for copying the DMI information in it - nothing more, nothing less, so all the modifying we must do is related to the new file i.e. new bios. Secondly if you try to read the guide more carefully you will see that you must remove the header from the bios.cap file extracted from the bios update executable downloaded from the manufacturer support page.
That's right - after extracting the bios.cap file from the update executable we must cut it to have the new (virgin) bios dump, and after moving the DMI information from our old dump to it we have the finished file ready to be programmed to the bios chip.
Don't want to be rude but that's B.S. Both old and new file must be 16,384 KB each.
Post #4 is about 41 version (GLCN41WW) of the bios, so first things first, the link for you to download this update executable is:
https://download.lenovo.com/consumer...s/glcn41ww.exe
Download the file, extract the bios.cap file from it, attach the file in your next post when ready, and we will continue to talk after that.
I didn't use GLCN41ww because that's a very old version. I used GLCN52WW.Reading all related posts is not enough, you must try to understand all the information in that posts otherwise you just read some text which obviously is not very fruitful as you (and I) can see.
I figured it out. I was following the post about extracting TDK files and it says to select/copy 0-800000 but my chip is 16 not 8. So, I made the adjustment and got the DMI info in. So, I am ready to hook up my programmer. I was making it much more complicated than it needed to be.
Thanks!Comment
The flash worked fine but my issue still exists. I have a motherboard virus that apparently can"t be removed. Flashing the spi was the last resort. I guess I will be throwing away a laptop I bought less than 3 years ago.Comment
by Marc97hello there,, anyone who can help us to have bios for LENOVO
HS461 HS561 HS761 NM-D251 REV 2.0
I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
i attached the .CAP may you can help us also to trim it.....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
