Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • skylinekiller
    • Mar 2024
    Originally posted by basalisco
    hi, not only do you need a programmer, but the most important part is the disassembly of the PC and the IC that contains the BIOS inside; perhaps you should try to read up and do a better job of understanding what it means.
    I have the laptop disassembled and my questioned had asked if there is a programmer out there where I wouldn't have to remove the chip..
    • basalisco
      • Mar 2024
      • 17
      • Italia
      #602
      considering the socket type and the operation to be performed, I don't think there are many alternatives, but maybe someone else with more experience could give you advice for what you asked
      • k3k5
        • Mar 2024
        • 6
        I created an adapter with a 3D printer, probe pogo pin, hot glue and jumper wire.
        Everything worked and now that I have found all the information (feature byte, build ID and factory host based MAC address).
        I installed the firmware from the HP driver page.​​
        • basalisco
          • Mar 2024
          • 17
          • Italia
          #604
          I'm interested, can I share the stl file?I'm interested, I was thinking about it too, can you share the stl file?
          • k3k5
            • Mar 2024
            • 6
            This is a prototype and was only tested on my mainboard.
            [MOD EDIT] External link removed,added attachment to post
            To flash, I used the official file "T76_01160000.bin" from HP's driver page.
            https://ftp.hp.com/pub/softpaq/sp151...0/sp151275.exe
            The Serial Number, Product Number, build_id and Feature Byte can be found on the inside of the cover.
            The CT Number and MAC Address can be found under the memory module.
            • basalisco
              • Mar 2024
              • 17
              • Italia
              #606
              this is the adapter that I designed, your case could be an excellent idea for containing it.
              In EasyEDA open source hardware lab, open source square pools all kinds of electrical design engineerings together to realize resource sharing easily.
              • nikola07
                • Sep 2018
                • 36
                • Ukraina
                #607
                Good afternoon, help me unlock the bios.
                elitebook 840 g8/
                sn 5CG34105CD
                • nikola07
                  • Sep 2018
                  • 36
                  • Ukraina
                  #608
                  help me with the file EC it is damaged
                  sn 5CG34105CD
                  • Orgun
                    • Mar 2024
                    • 12
                    • Brasil
                    #609
                    Hello friends.
                    I have a problem with my hp 840 G8
                    After updating the bios it didn't start, it just kept flashing the side light. I went to check the main dump behind the card and it was corrupted when reading. How is this possible? Is it possible to recover the main dump? help me please?
                    HP EliteBook 840 G8
                    SN: BRJ146RKMZ
                    CT: BKFNA035WF638B
                    IEC P/N : 6037B0161911
                    MAINBOARD: CORVETE - 6050A3217501 - MB - A01 (A1) (1086) L2​
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11888
                      #610
                      Originally posted by Orgun
                      Hello friends.
                      HP EliteBook 840 G8
                      SN: BRJ146RKMZ
                      CT: BKFNA035WF638B
                      Unlocked
                      • Orgun
                        • Mar 2024
                        • 12
                        • Brasil
                        #611
                        Originally posted by hoaca388
                        Unlocked
                        thankyou for support
                        Is this to be inserted into the second eprom or both? Sorry I don't have that much knowledge. I noticed that my programmer, after injecting the bios, gives an error when doing the check at the end.
                        • Muhammad Faizan
                          • Mar 2022
                          • 32
                          • 000
                          #612
                          fix this error plz.
                            SMDFlea commented
                            Editing a comment
                            Read the rules,post the laptop serial number
                        • Muhammad Faizan
                          • Mar 2022
                          • 32
                          • 000
                          #613
                          SERIAL NUMBER
                          • rex98
                            • Feb 2023
                            • 1281
                            • Mandaue CEBU, Philippines
                            #614
                            Originally posted by Muhammad Faizan
                            fix this error plz.
                            only flash this main do not touch the EC.
                            first boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
                            you can permanently disable absolute in BCU. Use BCU to fill these DMI info:
                            Serial Number: 5CG211478Z
                            Product #/SKU: 3K0M1UC#UUF
                            CT Number: PQSNL00WBGE77Z
                            Description: HP EliteBook 840 G8 Notebook
                            BuildID: 21WWCVET601#SUUF#DUUF
                            Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
                            MAC Address : 60:6D:3C:CB:E8:AD​
                            • Edgars UK
                              • Jul 2023
                              • 23
                              Hi everyone.
                              Please help remove password - clean my laptop bios.
                              Main and EC dumps are attached files.
                              Thanks in advance.
                              M/B CORVETTE-6050A3217501-MB-A01​
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11888
                                #616
                                Originally posted by Edgars UK
                                Hi everyone.
                                Thanks in advance.
                                You posted a missing serial number in the article.
                                  • 21173
                                  Hi everyone.
                                  Thanks in advance.
                                  Thread merged. Post the serial number -> https://www.badcaps.net/forum/troubl...before-posting
                                  • Edgars UK
                                    • Jul 2023
                                    • 23
                                    Hi everyone.
                                    Thanks in advance.
                                    SN#5CG1468T1M
                                    Thanks for the warning - I understood and will write down the serial number from now on.
                                    • minhdigital
                                      • Nov 2022
                                      • 758
                                      • Vietnam
                                      #619
                                      SN#5CG1468T1M
                                      Send to you
                                      • aldopc
                                        • Jul 2017
                                        • 465
                                        • Chilito
                                        #620
                                        Hellp me elitebook 840 g8, Hello, can someone help me rebuild the main bios, I have received this device with another base case, from an elitebook 845 g8, for the same reason I do not have the original serial number, I only have the dump of the ec chip, the board has the corvette code 6050A3217501-MB- A01 the main bios comes empty....
                                        • Buzzfuzz2k
                                          Bios password removal on a Unowhy dump
                                          by Buzzfuzz2k
                                          Hi Everyone,
                                          I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                          The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                          the Computer is a Unowhy small pc
                                          N° UYM6524702229
                                          After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                          My first attempt was to get the bios dump from windows...
                                          11-13-2023, 07:37 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
