Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • YASSINE BSSAA
    • Jan 2024
    • 10
    • الجزائر
    #681
    I tried many things and the device did not boot
    • farouk_1994
      • Mar 2021
      • 393
      • algeria
      #682
      you need main bios or the ec
      • YASSINE BSSAA
        • Jan 2024
        • 10
        • الجزائر
        #683
        EC
        MX25L25673GZ4I-08G _ 25R256JVEQ
        • farouk_1994
          • Mar 2021
          • 393
          • algeria
          #684
          Originally posted by marc_ytos
          Greetings, I hope someone can help me remove the password from the bios, my board has number 6050a3216701-mb-a01, serial number 5CG23614S8, the model is elite book 850 g8, apparently it shares a motherboard with Hp Zbook Firefly, that's why I'm posting here, I hope not to fall into any infringement, thank you, I hope for your help.
          Attached files​
          post the other chip bios and post it in hp elitebook 850 G8 thread
          • jonico2007
            • May 2022
            • 28
            • Philippines
            #685
            This device has SWAT lock
            Hp Elitebook 840 G8
            ​Device Freeze -78324
            S/N : 5CG2274BT3
            Prod Id: 509H3UC#UUF
            Please send me unlock for my dump
            • hoaca388
              Badcaps
              • Jan 2022
              • 11889
              #686
              Hp Elitebook 840 G8
              S/N : 5CG2274BT3
              HP EliteBook 840 G8 Notebook PC (509H3UC)
              • jonico2007
                • May 2022
                • 28
                • Philippines
                #687
                I already flashed the bios says it has password
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11889
                  #688
                  Post more ec file.
                  • jonico2007
                    • May 2022
                    • 28
                    • Philippines
                    #689
                    Post more ec file.
                    Heres one. Thank you
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11889
                      #690
                      File corrupted
                      • jonico2007
                        • May 2022
                        • 28
                        • Philippines
                        #691
                        I'm sorry I forgot to upload his file
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11889
                          #692
                          AAA
                          • jonico2007
                            • May 2022
                            • 28
                            • Philippines
                            #693
                            AAA
                            Thank you so much. It works!
                            • beast4ever
                              • Feb 2015
                              • 163
                              • egypt
                              #694
                              I need to clean my password
                              hp elitbook 830 g8
                              sn: 5cg2073c9n
                              prodid : 26d48av
                              • theboxsaysno
                                • Aug 2024
                                I'm still learning quite a bit from this group, so thank you! I was able to remove the bios password from the EC chip. I didn't touch the main. I'm getting hit with Endpoint security error. Any help would be appreciated.
                                HP Elitebook 840 G8
                                SN: 5CG2343RP6
                                PRODID: 6A3P3AV
                                • rex98
                                  • Feb 2023
                                  • 1281
                                  • Mandaue CEBU, Philippines
                                  #696
                                  HP Elitebook 840 G8
                                  SN: 5CG2343RP6
                                  PRODID: 6A3P3AV
                                  do not touch the EC, flash the original untouched EC. and this main.
                                  first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                  use BCU
                                  here's your DMI:
                                  Serial Number: 5CG2343RP6
                                  Product #/SKU: 6A3P3AV
                                  CT Number: PQSNP00WBH10R4
                                  Description: HP EliteBook 840 G8 Notebook
                                  BuildID: 21WWCVET601#SABA#DABA
                                  Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPgSguhKjhk8mEmwn7nVngpq.3B
                                  MAC Address : C4:75:AB:CF:C7:4F​
                                  • Orgun
                                    • Mar 2024
                                    • 12
                                    • Brasil
                                    #697
                                    After updating the bios it didn't turn on, only the side light kept flashing. I went to check the main dump behind the board and it was corrupted in the reading. Is it possible to generate the main and secondary bios? Donated!
                                    HP EliteBook 840 G8
                                    SN: BRJ146RKMZ
                                    CT: BKFNA035WF638B
                                    IEC P/N : 6037B0161911
                                    MAINBOARD: CORVETE - 6050A3217501 - MB - A01 (A1) (1086) L2​
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11889
                                      #698
                                      HP EliteBook 840 G8
                                      SN: BRJ146RKMZ
                                      CT: BKFNA035WF638B
                                      • dennis akumu
                                        • Mar 2018
                                        • 108
                                        • kenya
                                        #699
                                        Hp elitebook 840 g8 password locked please assist in unlocking this bios.
                                        prodduct id- 3V844UP#ABA
                                        S/N- 5CG1353XPG
                                        BOARD NO- CORVETTE- 6050A3217501-MB-A01 (A1) (1086) L2
                                        Attached is the main and Ec
                                        please help
                                        • rex98
                                          • Feb 2023
                                          • 1281
                                          #700
                                          S/N- 5CG1353XPG
                                          please help
                                          here you only said bios password. this won't remove device freeze/ absolute lock.
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
