Lenovo Yoga 710-14IKB bios
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys assist me with Lenovo Yoga 710 14Kb
    Turning on and no display at all, caps lock not turning on, checked the voltages , I receive most necessary volts for a board to work, cpu vcore available , I suggest the bios is corrupted please assist with a well known working bios please
    BIUY2_Y3 LA-D471P
    REV : 2.0
    2016-04-21
    S/N : MP174GDD MTM80v4001NSA
    • 21667
    Re: Lenovo Yoga 710-14IKB bios
    BIUY2_Y3 LA-D471P
    REV : 2.0
    2016-04-21
    bios + EC + DMI .
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      Originally posted by SMDFlea
      bios + EC + DMI .
      Brother I tried but didn't work man, still missing the VccGt of which I believe it's for Gfx core , all the power rails are running , even 1.05v as well, cpu core and more they are all okay, power goods as well but missing the VCCGT core near the CPU
        • 21667
        The bios is ok,its a virgin one extracted from lenovo update.
        • mgjini
          • Sep 2017
          • 199
          • united kingdom
          hi all
          i have this laptop which has bios pasword is a 7th gen laptop lenovo yoga 710-14ikb i tried lenovo autopatcher from here but it didn't wok, this bios gives password blues screen
          many thanks for help
          • Cashcobra
            Cashcobra commented
            Editing a comment
            You should flash (reprogram) EC
          • 21667
          Originally posted by mgjini
          hi all
          Serial number ?
          https://www.badcaps.net/forum/troubl...ore-posting​ .
          • mgjini
            mgjini commented
            Editing a comment
            Mp16q0vp serial
        • Cashcobra
          • Jul 2017
          • 26
          • GHANA
          • mgjini
            mgjini commented
            Editing a comment
            Hello, I am trying to read the ec I am using verytanov and 30 pin flex cable, do you have the settings for verytanov so I can read ec
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • AYsys
          Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
          by AYsys
          Hello dear forum members,
          I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
          I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
          Nothing was flashed here — the BIOS was only backed up.
          I created the backup using a CH341A Black programmer and NeoProgrammer....
          09-13-2025, 11:05 AM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • HotSaladMan
          Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
          by HotSaladMan
          *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
          Model : Lenovo ThinkBook 14S Yoga ITL
          S/N : MP28JT19
          MFG Date : 2022/02/09
          Factory ID PRC4
          MO : MPNXB26080FX
          MTM : 20WE001US
          MODULE FCC ID : PD9AX201NG
          IC : 1000M-AX201NG
          BOARD INFO
          FLV34 LA-KO51P
          REV : 1B 2020-08-24
          Bit of Info
          Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
          chip id, so i would always uncheck the id check, so it would bypass the error
          i did in fact make...
          11-07-2024, 07:46 AM
        • beogeek
          Lenovo Yoga Slim 7 14APU8 Bios Request
          by beogeek
          I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
          Attached is the bios dump in the state I received it...
          10-24-2024, 12:54 PM
