Lenovo Yoga 710-14IKB bios
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys assist me with Lenovo Yoga 710 14Kb
    Turning on and no display at all, caps lock not turning on, checked the voltages , I receive most necessary volts for a board to work, cpu vcore available , I suggest the bios is corrupted please assist with a well known working bios please
    BIUY2_Y3 LA-D471P
    REV : 2.0
    2016-04-21
    S/N : MP174GDD MTM80v4001NSA
    • 20699
    Re: Lenovo Yoga 710-14IKB bios
    BIUY2_Y3 LA-D471P
    REV : 2.0
    2016-04-21
    bios + EC + DMI .
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      Originally posted by SMDFlea
      bios + EC + DMI .
      Brother I tried but didn't work man, still missing the VccGt of which I believe it's for Gfx core , all the power rails are running , even 1.05v as well, cpu core and more they are all okay, power goods as well but missing the VCCGT core near the CPU
        • 20699
        The bios is ok,its a virgin one extracted from lenovo update.
        • mgjini
          • Sep 2017
          • 199
          • united kingdom
          hi all
          i have this laptop which has bios pasword is a 7th gen laptop lenovo yoga 710-14ikb i tried lenovo autopatcher from here but it didn't wok, this bios gives password blues screen
          many thanks for help
          • Cashcobra
            Cashcobra commented
            Editing a comment
            You should flash (reprogram) EC
          • 20699
          Originally posted by mgjini
          hi all
          Serial number ?
          https://www.badcaps.net/forum/troubl...ore-posting​ .
          • mgjini
            mgjini commented
            Editing a comment
            Mp16q0vp serial
        • Cashcobra
          • Jul 2017
          • 26
          • GHANA
          • mgjini
            mgjini commented
            Editing a comment
            Hello, I am trying to read the ec I am using verytanov and 30 pin flex cable, do you have the settings for verytanov so I can read ec
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • HotSaladMan
          Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
          by HotSaladMan
          *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
          Model : Lenovo ThinkBook 14S Yoga ITL
          S/N : MP28JT19
          MFG Date : 2022/02/09
          Factory ID PRC4
          MO : MPNXB26080FX
          MTM : 20WE001US
          MODULE FCC ID : PD9AX201NG
          IC : 1000M-AX201NG
          BOARD INFO
          FLV34 LA-KO51P
          REV : 1B 2020-08-24
          Bit of Info
          Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
          chip id, so i would always uncheck the id check, so it would bypass the error
          i did in fact make...
          11-07-2024, 07:46 AM
        • beogeek
          Lenovo Yoga Slim 7 14APU8 Bios Request
          by beogeek
          I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
          Attached is the bios dump in the state I received it...
          10-24-2024, 12:54 PM
        • grimacelord
          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
          by grimacelord
          Hello there.
          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
          History:
          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
          I searched for this error online and discovered...
          03-15-2023, 03:29 PM
        • Rdd KEuns
          Lenovo X1 Yoga Gen5 Full Bios chip dump request.
          by Rdd KEuns
          Hello, My lenovo x1 yoga gen5 laptop has been unstable and sometime freezes. After downgrading the bios i was normal for a moment but when back to being unstable.
          If anyone has an working bios please share it.
          Laptop lenovo x1 yoga gen5. serial number PF-2MSZ9Q. Type number 20UC-S2410N. Motherboard model number GX4A0/GY650 NM-C881 Rev1.0. Bios chip GD25B256DYIG...
          03-21-2025, 05:49 AM
