HP ProBook 650 G4
  • JParker13
    • Sep 2023
    • España
    #41
    HP Probook 650 g4
    A relative has bought a used laptop online and has asked me to check if I can remove the messages that appear when starting the laptop.
    The following two messages appear
    - Your system is not fully configured. Please contat HP customer support
    -This BIOS is not for Production Use
    I have tried to update the bios but it gives error. The bios version is Ver 80.31.00.
    Thanks.
    • ribar96
      • Apr 2023
      • 36
      • Bosna and Herzegovina
      #42
      Re: HP ProBook 650 G4
      Hello people
      I need help, I need to unlock the bios on my hp, but I don't see the bios chip, does anyone have a picture where I can find it. thank you in advance.
      • peste
        • Dec 2016
        • 13426
        • ROMANIA
        #43
        Originally posted by ribar96
        Hello people
        well, you'd better post clear pictures of the motherboard on both sides..
        • ribar96
          • Apr 2023
          • 36
          #44
          attached is a picture of the motherboard, and the label is
          CHROMIA-60650A2930001-MB-A01(A1)
          You can see on the board where I was trying to remove one chip it said winboard, but I'm not sure if that's it.
            • 21679
            Post the part number etched onto both of the WSON8 chips.
            • ribar96
              • Apr 2023
              • 36
              #46
              you mean these two chips. thanks in advance
                • 21679
                Yep ,backup the 25Q128 chip. If its only got an admin pass RCUnlocker will unlock it.If it has a user pass as well backup the other chip and post both. Please post the laptop serial number,its required.You`ll find links to RCUnlocker if you read - https://www.badcaps.net/forum/showthread.php?t=103570
                • ribar96
                  • Apr 2023
                  • 36
                  #48
                  my main problem is that you were locked to me :/
                  which chip should I download to be able to take the bios program with it? I'm a beginner in this so I'm interested?
                    • 21679
                    Backup both of them,then post both.
                    • ribar96
                      • Apr 2023
                      • 36
                      #50
                      my programmer is not good enough for this chip and i can't read it. I use EZP2019, can you recommend another better one so I can order for Bosnia?
                      • hieu13pro
                        • Jun 2023
                        • 32
                        • viet nam
                        #51
                        Hello, my device is having an error. The problem is that after 10 minutes of use, the device automatically resets. This is my old bios backup, please help me fix it.
                        HP ProBook 650 G4 BIOS CHROMIA-6050A2930001-MB-A01
                        series: 5CG9104X7Q​
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12268
                          #52
                          series: 5CG9104X7Q​
                          HP ProBook 650 G4 Notebook PC - Q83
                          • bykanovm
                            • Aug 2022
                            • 95
                            • Украина
                            #53
                            Help me with BIOS on 650 G4 motherboard CHROMIA-6050A2930001-MB-A01(A1)
                            SN 5CG91625N3
                            In my old one there is a black screen and gradually the fan turns at maximum speed​
                            • bykanovm
                              • Aug 2022
                              • 95
                              • Украина
                              #54
                              I'll add to my post above. I flashed the laptop with a set of EC and MAIN bios from post No. 6. The laptop began to turn on, which indicates that the hardware is completely working. But when you turn it on, the fan starts turning at full speed, then it stops and works normally. It also takes a long time to turn on, the screen is dark for about 40 seconds. This is understandable, since the BIOS is from another laptop. I can't collect a working dump from my original and the update from the site. Please help me. 2 original bios in the archive.
                              650 G4 CHROMIA-6050A2930001-MB-A01(A1)
                              SN 5CG91625N3
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12268
                                #55
                                SN 5CG91625N3
                                HP ProBook 650 G4 Base Model Notebook PC
                                • bykanovm
                                  • Aug 2022
                                  • 95
                                  • Украина
                                  #56
                                  Thanks, the BIOS works.
                                  But when turned on, it shows the message "HP Endpoint Security Controller Problem"
                                  I don’t know the password on the old original BIOS, the laptop wouldn’t turn on.​
                                  • bykanovm
                                    • Aug 2022
                                    • 95
                                    • Украина
                                    #57
                                    I corrected the error, flashed my original EC, and 32MB BIOS from hoaca388, for which many thanks to him!
                                    • nefaa
                                      • Feb 2016
                                      • 9
                                      • Tunisie
                                      #58
                                      plz dump for my corrupted bios CHROMIA-6050A2390001-MB-A01(A1)
                                      Serial: 5CG93684V6
                                      ProdID: 2GN02AV
                                      thx in advance
                                      • x44n
                                        • Jan 2024
                                        • 10
                                        • Niemcy
                                        #59
                                        Hello
                                        need clear bios and ec, many faults
                                        CHROMIA 6050A2930001-MB-A01(A1)
                                        ​Serial: 5CG9111780
                                        ProdID: 3UP57EA#ABD
                                        THANK YOU in advance
                                        • Mahesa09
                                          • Nov 2021
                                          • 67
                                          • jakarta
                                          #60
                                          hello sir can you help me hp 650 g4. and i problem
                                          hp endpoin security controller problem.
                                          give me fix the problem SN 5CG9164QM3
                                          Badcaps Electronics Repair Forum & Schematic Search
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
