HP ProBook 650 G4
  • JParker13
    • Sep 2023
    • España
    #41
    HP Probook 650 g4
    A relative has bought a used laptop online and has asked me to check if I can remove the messages that appear when starting the laptop.
    The following two messages appear
    - Your system is not fully configured. Please contat HP customer support
    -This BIOS is not for Production Use
    I have tried to update the bios but it gives error. The bios version is Ver 80.31.00.
    Thanks.
    • ribar96
      • Apr 2023
      • 35
      • Bosna and Herzegovina
      #42
      Re: HP ProBook 650 G4
      Hello people
      I need help, I need to unlock the bios on my hp, but I don't see the bios chip, does anyone have a picture where I can find it. thank you in advance.
      • peste
        • Dec 2016
        • 12334
        • ROMANIA
        #43
        Originally posted by ribar96
        Hello people
        well, you'd better post clear pictures of the motherboard on both sides..
        • ribar96
          • Apr 2023
          • 35
          #44
          attached is a picture of the motherboard, and the label is
          CHROMIA-60650A2930001-MB-A01(A1)
          You can see on the board where I was trying to remove one chip it said winboard, but I'm not sure if that's it.
            • 20446
            Post the part number etched onto both of the WSON8 chips.
            • ribar96
              • Apr 2023
              • 35
              #46
              you mean these two chips. thanks in advance
                • 20446
                Yep ,backup the 25Q128 chip. If its only got an admin pass RCUnlocker will unlock it.If it has a user pass as well backup the other chip and post both. Please post the laptop serial number,its required.You`ll find links to RCUnlocker if you read - https://www.badcaps.net/forum/showthread.php?t=103570
                • ribar96
                  • Apr 2023
                  • 35
                  #48
                  my main problem is that you were locked to me :/
                  which chip should I download to be able to take the bios program with it? I'm a beginner in this so I'm interested?
                    • 20446
                    Backup both of them,then post both.
                    • ribar96
                      • Apr 2023
                      • 35
                      #50
                      my programmer is not good enough for this chip and i can't read it. I use EZP2019, can you recommend another better one so I can order for Bosnia?
                      • hieu13pro
                        • Jun 2023
                        • 29
                        • viet nam
                        #51
                        Hello, my device is having an error. The problem is that after 10 minutes of use, the device automatically resets. This is my old bios backup, please help me fix it.
                        HP ProBook 650 G4 BIOS CHROMIA-6050A2930001-MB-A01
                        series: 5CG9104X7Q​
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11379
                          • Viet Nam
                          #52
                          series: 5CG9104X7Q​
                          HP ProBook 650 G4 Notebook PC - Q83
                          • bykanovm
                            • Aug 2022
                            • 95
                            • Украина
                            #53
                            Help me with BIOS on 650 G4 motherboard CHROMIA-6050A2930001-MB-A01(A1)
                            SN 5CG91625N3
                            In my old one there is a black screen and gradually the fan turns at maximum speed​
                            • bykanovm
                              • Aug 2022
                              • 95
                              • Украина
                              #54
                              I'll add to my post above. I flashed the laptop with a set of EC and MAIN bios from post No. 6. The laptop began to turn on, which indicates that the hardware is completely working. But when you turn it on, the fan starts turning at full speed, then it stops and works normally. It also takes a long time to turn on, the screen is dark for about 40 seconds. This is understandable, since the BIOS is from another laptop. I can't collect a working dump from my original and the update from the site. Please help me. 2 original bios in the archive.
                              650 G4 CHROMIA-6050A2930001-MB-A01(A1)
                              SN 5CG91625N3
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11379
                                • Viet Nam
                                #55
                                SN 5CG91625N3
                                HP ProBook 650 G4 Base Model Notebook PC
                                • bykanovm
                                  • Aug 2022
                                  • 95
                                  • Украина
                                  #56
                                  Thanks, the BIOS works.
                                  But when turned on, it shows the message "HP Endpoint Security Controller Problem"
                                  I don’t know the password on the old original BIOS, the laptop wouldn’t turn on.​
                                  • bykanovm
                                    • Aug 2022
                                    • 95
                                    • Украина
                                    #57
                                    I corrected the error, flashed my original EC, and 32MB BIOS from hoaca388, for which many thanks to him!
                                    • nefaa
                                      • Feb 2016
                                      • 9
                                      • Tunisie
                                      #58
                                      plz dump for my corrupted bios CHROMIA-6050A2390001-MB-A01(A1)
                                      Serial: 5CG93684V6
                                      ProdID: 2GN02AV
                                      thx in advance
                                      • x44n
                                        • Jan 2024
                                        • 7
                                        • Niemcy
                                        #59
                                        Hello
                                        need clear bios and ec, many faults
                                        CHROMIA 6050A2930001-MB-A01(A1)
                                        ​Serial: 5CG9111780
                                        ProdID: 3UP57EA#ABD
                                        THANK YOU in advance
                                        • Mahesa09
                                          • Nov 2021
                                          • 63
                                          • jakarta
                                          #60
                                          hello sir can you help me hp 650 g4. and i problem
                                          hp endpoin security controller problem.
                                          give me fix the problem SN 5CG9164QM3
                                          Badcaps Electronics Repair Forum & Schematic Search
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
