ASUS X705UVP Bios
  • Conste
    • Oct 2018
    • 235
    ASUS X705UVP Bios
    My ASUS F705UA (this is standing on the baseplate) just bricked itself with an UEFI update.
    Tried a bios dump from the www but problem is the same, no screen and battery light blinking white.
    Could somebody please repair my original one?
    Mainboard: X705UVP Rev. 2.1
    Thanks in advance.
    • 21692
    Re: ASUS X705UVP Bios
    Post a picture of the white barcode sticker on the motherboard
    • Conste
      • Oct 2018
      • 235
      Downloaded 2 files from fixbios for money, but no sucess.
      Picture is attached
        • 21692
        Picture is attached
        Those aren`t the stickers i would hope you would post. The stickers are like the ones in this thread - https://www.badcaps.net/forum/showthread.php?t=96604 .Sometimes there`s QR codes instead ,or no stickers at all.
        So the laptop model is F705UA ,the motherboard silkscreened part number is X705UVP Rev. 2.1 ,and we don`t know if there should be another sticker or not (with a model number and bios version), so its hard to find which bios you need .
        Your bios update was to X705UVP and that doesn`t seem to be working.The F705UA support page has X705UAR - https://www.asus.com/FR/supportonly/...HelpDesk_BIOS/ ,we`ll try that one
        did you check if the bios from the "paid" site had clean ME firmware
        • Conste
          • Oct 2018
          • 235
          I think the correct model is
          X705UAP, because I can also find this string in my bios file using ctrl + f
          https://www.asus.com/supportonly/X705UA/HelpDesk_BIOS/
          /Edit: No sucess. Could you build a dump of X705UAP, please?
            • 21692
            X705UAP me clean. My bad,i should have looked at the strings too.
            • Conste
              • Oct 2018
              • 235
              Thanks!
              But sadly, no change.
              I can see that one rail in CPU area is not coming on, but since there is no schematic I guess the chance to repair it is very low.
              Could it be that the KBC has a bad flash?
                • 21692
                X705UVP Bios
                • Conste
                  • Oct 2018
                  • 235
                  Thanks, but still the same
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • grimacelord
                    by grimacelord
                    07-10-2025, 02:52 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • studdy05
                    Bricked HP Probook 450 G7 Bios questions
                    by studdy05
                    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                    Ive got...
                    07-08-2025, 09:24 PM
