Lenovo Ideapad S145-15IIL BIOS
    • 21922
    Originally posted by Daniel Remiszewski
    Hello, i have problem with BIOS in S145-15IIL. Laptop had problem with blinking power button. I've tried to copy DMI 622000 - 623FFF, but it doesnt work. Without editing BIOS laptop is working fine, but i dont have serial number etc.
    EC DKEC24WW
    I've used DKCN55WW.
    I suspect my DMI may be damaged​
    Original BIOS in attachments.
    Try this one, if it doesn`t work i`ll post another version.
    • Daniel Remiszewski
      • Dec 2024
      Clean DKCN55WW works good, but laptop is dead when im trying to paste my DMI.
      I used DMI from another laptop and it works, but i want to have my DMI
      Is this file you uploaded with my DMI from ori bios?
        • 21922
        Yes. Try it, and if it doesn`t work use the DMI from another, then change DMI with Lenovo Golden Key U1 tool https://www.badcaps.net/forum/troubl...24#post1622424
        • diegito11
          • Jul 2016
          • 94
          • España
          #64
          Hello colleagues, I'm also having problems with the BIOS of a Lenovo S145-15IIL Placanm-c711 serial number PF21GTSC. I'm sending you the original BIOS because I'm not very familiar with the hexadecimal tool yet.
          • peste
            • 13599
            • ROMANIA
            #65
            you have everything you need at post #33
            https://www.badcaps.net/forum/troubl...s-please/page2
            • diegito11
              • Jul 2016
              • 94
              • España
              #66
              Thanks for answering and helping me. I went to the link you mentioned in post 33, but it's not working. I get this message: "Invalid File Specified."
                • 21922
                Try it again. If you can`t add the DMI yourself let us know
                • diegito11
                  • Jul 2016
                  • 94
                  • España
                  #68
                  Hello, I have reprogrammed the file but I still have the same symptom, the processor turns on, heats up but I have no video, the screen doesn't even flash, I have tried with an external monitor and nothing, it is strange in this model because I have had the same problem with many Lenovos and entering the BIOS solved it but this one is making me sweat, as for entering the DMI files, I can't find a tutorial, can you help me?
                    • 21922
                    It should boot ok without the DMI, check hardware and if you fix that can add DMI later
                    • diegito11
                      • Jul 2016
                      • 94
                      • España
                      #70
                      Well, I've checked all the subsources. CPU, memory, always 3V and 5V source and everything is correct, the processor heats up quite a bit so I think it's because of the BIOS, worse as I told you, it's strange that I've tried several and it doesn't work.
                        • 21922
                        Backup the bios chip again, open it with ME Analyzer, if it says the File System State is Configured then the PCH hasn`t even read the bios chip, if it`s Initialised the bios has been read. You can try another chip, look carefully at your soldering and for missing parts, then keep checking hardware, get the schematic if it`s available and look at the power sequence.
                        • diegito11
                          • Jul 2016
                          • 94
                          • España
                          #72
                          This image is the one that appears when I execute the original file, so I don't know if it was copied correctly or if that bios was already damaged. Regarding the chip, normally the reprogrammer detects when the chip is bad and this is not the case.
                          Let's see if I make a copy of the one I had later and look at it with my analyzer to see what comes out.
                          I put in the second photo the result of the bios
                            • 21922
                            Your ME Analyzer version is very old, update to a newer one.
                            • jeffer dacon
                              • May 2022
                              • 35
                              • colombia
                              #74
                              Hi guys, please help.
                              Disable RAM.
                              Lenovo S145-15II
                              Board name: GS44D/GS54D NM-C711 REV 1.0
                              Winbond BIOS 25Q128JV
                              • jeffer dacon
                                • May 2022
                                • 35
                                • colombia
                                #75
                                Disable RAM.
                                Lenovo S145-15II
                                BIOS OKEY
                                • diegito11
                                  • Jul 2016
                                  • 94
                                  • España
                                  #76
                                  Well, one of the things I had in mind was to deactivate the RAM on the motherboard but I wanted to leave it for last as a last resort. Well after all I decided to reprogram a file to deactivate it and I see that another colleague has also put it in, and surprise it gave me a screen and bios light.
                                  My next question is, since the integrated memory has been disabled, it would only work with the memory slot I put in it, right? And I couldn't update the bios to the latest version, right? Since I would deactivate everything again? it's right?
                                    • 21922
                                    Yes and yes. Attached is bios version DKCN55WW (the latest and last one from lenovo support dated 22 Jul 2022) with your DMI + ram disabled.
                                    • shybear
                                      • Jan 2010
                                      • 105
                                      #78
                                      I'va also a problem with this model:
                                      Ideapad S145-15IIL- Type 81W8
                                      s/n PF1BY7NE
                                      Mainboard: GS44D/GS54D NM-C711 Re.v 1.0
                                      I tried to program BIOS using the virgin one on post #7 but witout any success.
                                      Power works and battery charge but if I press ON, white power ON LED start to blink and stops only if I keep pressed power button.
                                      I also tried to use an other DDR4 on RAM slot and removed it.
                                      Reading other posts make me feel that problem may be in the BIOS so before to erase chip I made a backup copy fo the original that attach here.
                                      • shybear
                                        • Jan 2010
                                        • 105
                                        #79
                                        s/n PF1BY7NE
                                        Continuing reading the thread I wanted try the one of #33 and machine finally worked but was really instable and sometimes fan did not spin and machine was blocked with black screen. I sorted out that maybe this was a problem with defective onboard ram so I wanted to reprogram BIOS with the BIOS of # 77 No screen output - cap prob? At first it seems that this fixed the problem but while I was testing with Windows running it shut off for itself and I took a lot of tries to make it work again.
                                        I really didn't know what was going on because mainboard was in good status but while I was examinating I saw just near the CPU a sort of dirt. (see pictures before and next with microscope).
                                        I claned it carefully and next laptop started to works properly.
                                        So I reprogrammed BIOS with the last one of post #33 and next I updated it again via Windows so it update also the EC part.
                                        Finally with U1 Tool I was able to insert DMD.
                                        Click image for larger version  Name:	Ideapad S145.jpg Views:	0 Size:	150.2 KB ID:	3726973
                                        Click image for larger version  Name:	Ideapad S145_clean.jpg Views:	0 Size:	199.8 KB ID:	3726974
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
