Lenovo Ideapad S145-15IIL BIOS
  • peste
    • 13599
    • ROMANIA
    #41
    Re: Lenovo Ideapad S-145-15IIL BIOS
    Originally posted by Fadda88
    With my bios i have no image, no blinks, please help I need bios without on board ram, I had to remove them for a Short
    you have everything you need at #7.post..
    • Fadda88
      • May 2017
      • 12
      • Italy
      #42
      I tried that one but same issue.
        • 21922
        Try this one,its only to test,i don`t think it will work.
        EDIT: Removed bios,not working
        • Fadda88
          • May 2017
          • 12
          • Italy
          #44
          Thanks I'm trying it, I'll let you know
          • Fadda88
            • May 2017
            • 12
            • Italy
            #45
            Just tested it, but nothing, white led on power button but nothing on display, I removed onboard ram for a short, and I'm using sodimm only.
            thanks.
              • 21922
              thanks.
              I removed the bios as its not working,someone else might post one for you to try.You might have to disable onboard ram by resistor straps,if its doable that way.You will have to find a schematic and boardview
              • Fadda88
                • May 2017
                • 12
                • Italy
                #47
                thanks anyway
                • Jokerx84
                  • Sep 2017
                  • 52
                  • Hungary
                  #48
                  Hello!
                  So-dimm doesn't work for me, idea
                  • peste
                    • 13599
                    • ROMANIA
                    #49
                    Originally posted by Jokerx84
                    Hello!
                    post the original bios..
                    • Jokerx84
                      • Sep 2017
                      • 52
                      • Hungary
                      #50
                      • peste
                        • 13599
                        • ROMANIA
                        #51
                        try..
                        • Jokerx84
                          • Sep 2017
                          • 52
                          • Hungary
                          #52
                          try..
                          RT809F File open error
                            • 21922
                            Renaming the file might help.
                            • Jokerx84
                              • Sep 2017
                              • 52
                              • Hungary
                              #54
                              I tried, but it didn't help either
                              • ahlebinin
                                • Aug 2023
                                • Russia
                                #55
                                Did you manage to solve the problem by flashing?
                                How can I make a bios firmware with disabled checking of the built-in RAM?
                                • geethmadu
                                  • Mar 2023
                                  • 39
                                  • united kingdom
                                  #56
                                  The laptop has no display but it switchs on. Can someone please check whether the original BIOS bin is corrupted?
                                  Lenovo Ideapad S145-15IIL - GS44D GS54D NM-C711
                                  • peste
                                    • 13599
                                    • ROMANIA
                                    #57
                                    you have everything you need at post #33
                                    https://www.badcaps.net/forum/troubl...s-please/page2
                                    • dozergrf
                                      • Apr 2025
                                      • Nicolás Romero
                                      #58
                                      ec bios s145-15IIL rev1.0 core i3 10th
                                      • peste
                                        peste commented
                                        Editing a comment
                                        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                    • peste
                                      • 13599
                                      • ROMANIA
                                      #59
                                      post S/N, full name and model, motherboard model,TYPE,etc.
                                      • Daniel Remiszewski
                                        • Dec 2024
                                        Hello, i have problem with BIOS in S145-15IIL. Laptop had problem with blinking power button. I've tried to copy DMI 622000 - 623FFF, but it doesnt work. Without editing BIOS laptop is working fine, but i dont have serial number etc.
                                        EC DKEC24WW
                                        I've used DKCN55WW.
                                        I suspect my DMI may be damaged​
                                        Original BIOS in attachments.
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
