Lenovo Ideapad S145-15IWL BIOS
  • Italianjob80
    • Sep 2024
    • 5
    • Italia
    #41
    Re: Lenovo Ideapad S-145-15IIL BIOS
    Bios estratto dall'aggiornamento Lenovo.
    Ciao ragazzi,
    ho bisogno di questi file che avete pubblicato, ma dopo aver scaricato il file, l'archivio è danneggiato, potreste fornirmi il file di backup aggiornato?
    Grazie
    Hi guys,
    I need these files you posted, but after downloading the file, the archive is corrupted, could you provide me the updated backup file?
    Thanks​
    in English please..
    PS:
    I found the file attached to Giacomo's post, I will try that and let you know. Thank you very much
    • peste
      • 13377
      • ROMANIA
      #42
      Originally posted by Italianjob80
      Ciao ragazzi,
      Grazie
      Hi guys,
      Thanks​
      in English please..
      PS:
      the archive has nothing, update winrar or use 7zip
      • Italianjob80
        • Sep 2024
        • 5
        • Italia
        #43
        Good evening,
        sorry for the language.
        I wanted to ask a question.
        My girl notebook turned off during the bios update and now the power light is flashing.
        the model is:
        Lenovo S145-15IWL
        Model:81MV
        S/N: PF14F22Q MTM:81MV010CIX
        Mfg Date:19/08/29 Factory ID:JVHFC1
        MO:PF9XB9829106
        I opened the laptop, disconnected the battery and the buffer, I also pressed the reset button on the sides but nothing.
        Can I use the file from Giacomo post? or do I have to change it?
        unfortunately I can't find the place I saw, but I downloaded the file
        I put the file S_145_ASCNXXWW.bin used by Giacomo on an appropriately formatted pen following the guide and giving the name to the file "Format fs=fat32 label=CD_Crisis"
        I inserted the pen drive into the USB port where the power supply is, I inserted the power cable, by pressing Fn+R I pressed the power button, I noticed that the power light flashes orange 5 times
        then it turns white and starts flashing again, then I leave Fn+R and the computer turns off and on continuously as before, with the on light flashing, nothing happens.
        what should I do?​
        thanks
        • Italianjob80
          • Sep 2024
          • 5
          • Italia
          #44
          Originally posted by volinakis
          try
          this bios.
          • volinakis
            • Jan 2021
            • 2872
            • N/A
            #45
            Good evening,
            the model is:
            Lenovo S145-15IWL
            Model:81MV
            MO:PF9XB9829106
            what should I do?​
            thanks
            that file is for writing bios chipset not for recovery. Try this file, copy it in USB stick as is (unpacked, of course) and see what happens.
            • Italianjob80
              • Sep 2024
              • 5
              • Italia
              #46
              Good morning,
              I tried, unfortunately nothing changes.
              I inserted the device into the USB port next to the power supply, pressed Fn+R and turned on the laptop, the orange power supply LED flashed 5 times and always does so, until I hold down Fn+R, then it goes back to the way it was before.
              Fn+R I have to keep it pressed until the power supply LED starts flashing correctly, then I have to remove it.
              Thank you for your availability, if you have another solution I am grateful.
              best regards
              • stephenjames
                • Feb 2009
                • 14
                • England
                #47
                Can anyone please help regarding corrupted bios bin file? Serial Number: PF14A3E6, 81MV, MTM:81MV00ANUK JVHFC1.
                Original file Attached.​
                  • 21641
                  Thread merged. Everything you need is right here in this thread, read all posts.
                  • servicepcpascani@gmail.co
                    • Oct 2022
                    • 29
                    • romania
                    #49
                    MODEL 81MV
                    SN: PF14BRL6 MTM: 81MV00MXRM
                    FACTORY ID: JVHFC1
                    MO: PF9XB9824210
                    HELLO! can you help me with a new bios?
                    • shiyab
                      • Sep 2023
                      • 1592
                      • india
                      #50
                      Originally posted by servicepcpascani@gmail.co
                      s145-15iwl
                      mo: pf9xb9824210
                      sn: pf14brl6
                      mtm: 81mv00mxrm
                      hi! can you help me with a new bios?
                      thx
                      hi try new file
                        • 21641
                        MODEL 81MV
                        FACTORY ID: JVHFC1
                        MO: PF9XB9824210
                        A bios and DMI offsets are at post 22. If you can`t add the DMI (serial number etc) yourself let us know.
                          • Oct 2022
                          • 29
                          • romania
                          #52
                          Originally posted by shiyab
                          hi try new file
                          not working, bliking power led..
                          • Golden444
                            • Jul 2018
                            • Serbia
                            #53
                            Originally posted by the Benninger
                            hi try post#16 and now not even the LED that indicates that it is charging works, some other suggestion I am open to listen and execute, thanks
                            Fair warning for anyone who has flashed the bios several times (or is going to) and the results are the same, either no picture or the power light is blinking... ,
                            PAY ATTENTION to your board everywhere where are white circles, where the cover touches the board, in my case some small lines on the circuit where broken by friction from the spacers, so yes bad design , but it can be fixed.
                            • Leonardo Vasconcellos
                              • May 2025
                              • Brasil
                              #54
                              Hello, everyone!
                              I'm facing a problem with a corrupted BIOS and I'm having trouble finding the correct .bin file to re-flash the BIOS on the burner. I've looked in several places, but without success so far.
                              Below is the complete information about the equipment:
                              Model: Lenovo S145-15IWL
                              MO: PEN039A23074
                              MTM: 81S9000GBR
                              S/N: PE0544K4
                              Motherboard: FV440 / FS441 / FS540 - NM-C121 Rev: 1.0 (Date: 2018-12-12)
                              BIOS Chip: Winbond 25Q128JVSQ
                              If anyone has this .bin file (or even the functional BIOS dump) or knows where I can find it safely, I'd really appreciate any help!
                              Thanks!​
                                • 21641
                                Originally posted by Leonardo Vasconcellos
                                Hello, everyone!
                                I have translated your post to English as this is an english language forum. You will find everything you need in this thread topic, make a good backup first before you try any other bios.
                                • duckmansweb@bigpond.com
                                  • Sep 2022
                                  Hi guys, im looking for a bios file for a lenovo ideapad s145-15iwl - model: 81MV - BOARD FV440/fs441/fs5540 rev 1.0 - serial# PF1XERSD
                                    • 21641
                                    https://www.badcaps.net/forum/troubl...17#post1786056
                                    • jendkkd jeje
                                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                      by jendkkd jeje
                                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                      10-11-2024, 03:12 PM
                                    • joven016
                                      Lenovo Ideapad S145 need working bios HELP!!
                                      by joven016
                                      Problem is blinking power led only
                                      i don't know exactly if it's s145-15igm or s145-14igm
                                      have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                      Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                      Already tested some of posted bios here
                                      S145-14igm - success but invalid serial and not booting on OS
                                      S145-15igm - success with serial and some other info in bios but still not booting on OS
                                      already tried installing new windows but always booting on bios setup
                                      windows installer flash drive detected on...
                                      08-21-2025, 10:55 PM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • mximiliandz
                                      help bios lenovo ideapad s145-14iil type 81w6
                                      by mximiliandz
                                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                      06-20-2025, 06:50 AM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
