Lenovo Ideapad S145-15IWL BIOS
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Hi friends,
    I have a problem on Lenovo Ideapad S-145-15IWL NM-C121. Can't open windows 10. Freezing on windows installation. I to Upload bios version 38ww and it worked well but when i update it to 51ww version it freeze again, and it shows 0xc000000f error message. I try to install again it freeze while opening the installation screen. Can anyone help me.
    • 22119
    Re: Lenovo Ideapad S-145-15IIL BIOS
    Originally posted by raajkumar
    Hi friends,
    Post your backup,and serial .
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      Re: Lenovo Ideapad S-145-15IWL BIOS
      here my backup file i attached.
      LENOVO IDEAPAD S145-15IWL
      MODEL : 81MV
      S/N: PF1P88FR
      MTM: 81MV008AUS
      FACTORY ID: JVHFC1
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        anyone can help me ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Bios extracted from lenovo update.
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Thanks for your help. I will try and get back to you.
            • raajkumar
              • Mar 2015
              • 354
              • Srilanka
              Sorry Bro. I upload the bios dump on that chip but not showing anything on screen. Its switched on and its off after 20seconds and on again but nothing on screen even screen not switched on and keyboard not responding ( CAP's lock key ) do you have any solution on it?
              • bel77
                • May 2013
                • 34
                • jordan
                lenovo IdeaPad S145-15IWL
                tested
                work good
                • claudiunew
                  • Sep 2022
                  Lenovo Ideapad s145-15IWL BIOS needed
                  Hi friends,
                  I need a BIOS for Lenovo Ideapad s145-15IWL, model name : 81MV.
                  If failed on my during a previos BIOS update.
                  MB name : F440/FS441/FS540 NM-C121
                  REV 1.0
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    Re: Lenovo Ideapad s145-15IWL BIOS needed
                    Originally posted by claudiunew
                    Hi friends,
                    REV 1.0
                    Upload your original bios file and write you device serial number.
                    all donations are welcome,
                    • mester
                      • Oct 2021
                      • 8
                      • indonesia
                      lenovo IdeaPad S145 Flashing Power Button Led
                      i also have the same problem, the led indicator is blinking and no screen display. please someone to fix my old backup bios
                      here are the laptop details and the original bios is attached
                      lenovo ideapad s145-15IWL
                      Motherboard: FV440/FS441/FS540 NM-C121 Rev. 1.0
                      Serial Number:PF1Y210W
                      Model:81MV
                      THANKYOU
                      • hardware1
                        • Sep 2021
                        • 2949
                        • N/A
                        Re: lenovo IdeaPad S145 Flashing Power Button Led
                        Model:81MV
                        THANKYOU
                        Here's your New Bios, it's a Virgin Bios from Lenovo with your DMI.
                        • andymanley
                          • Jan 2014
                          Guys sorry to drag this string up again however we are struggling. We have a lenovo S-145-15IWL with a flashing power light. Usually, this is a bios corruption and we would order a programmed BIOS chip and solder on however to save time we have purchased a chip programmer in order to solve it straight away.
                          The model is S-145-15IWL
                          Serial number - PF1TW1D3
                          Model - 81MV
                          Motherboard FS540 10 F2
                          I have downloaded the EXE bios from Lenovo which includes an F2 file that is too large for the chip once extracted and have tried a couple from BC however still getting light flash on boot.
                          Could anyone please supply an appropriate bios which is compatible with the above model?
                          Thanks in advance!
                            • 22119
                            Model - 81MV
                            Thanks in advance!
                            Did you make a backup of the bios before you tried any others. Post it here if you did.
                            • andymanley
                              • Jan 2014
                              Sorry no - Assume now dead?
                              • hardware1
                                • Sep 2021
                                • 2949
                                • N/A
                                If you have no Backup try this file, it could help you.
                                • emanuelbl
                                  • Jan 2024
                                  • Brazil
                                  i also have the same problem, the led indicator is on and no screen display.
                                  lenovo ideapad S145-15IWL
                                  Serial Number:PE05CA6W
                                  Model:81S9
                                  I'm attaching the bios backup, but i guess it is not correct
                                  • the Benninger
                                    • Nov 2022
                                    • 189
                                    • venezulan
                                    hi Folks, this machine dot no powerup
                                    Model: S145-15IWL
                                    MO: PE9039C22034
                                    MTM:8159000DBR
                                    S/N:PE05C3W2
                                    mb: FV440/FS441/FS540 - NM-C121 Rv: 1.0 2018-12-12
                                    • peste
                                      • 13759
                                      • ROMANIA
                                      Model: S145-15IWL
                                      MO: PE9039C22034
                                      MTM:8159000DBR
                                      S/N:PE05C3W2
                                      try post#16
                                      • the Benninger
                                        • Nov 2022
                                        • 189
                                        • venezulan
                                        Originally posted by peste
                                        try post#16
                                        hi try post#16 and now not even the LED that indicates that it is charging works, some other suggestion I am open to listen and execute, thanks
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
