Problem with flashing MX25L12873F
  • onelook
    • May 2020
    • 27
    Hi guys,
    I am having problem with flashing (writing) BIOS Chip MX25L12873F on HP 830 G6.
    With the flashrom software in Linux i got the error:
    Erasing and writing flash chip... FAILED at 0x00011000! Expected=0xff, Found=0x00, failed byte count from 0x00011000-0x00011fff: 0x18
    ERASE FAILED!
    Looking for another erase function.
    FAILED at 0x00018000! Expected=0xff, Found=0x00, failed byte count from 0x00018000-0x0001ffff: 0x12
    Then i used Asprogrammer in Windows it showed me:
    Possible protection is enabled. Press "Unprotect" and check datasheet
    I have pressed "Unprotect" but no success
    The Reading was good without any problem. Both in Linux and Windows. All the read files have same SHA256 Checksum.
    I think there's something block writing on the Chip.
    Maybe you can help.
    Thank you
    • 20643
    Re: Problem with flashing MX25L12873F
    Is the chip desoldered,or are you using a clip
    • onelook
      • May 2020
      • 27
      The chip is desoldered.
      I am using CH341a Black. I mean i haven't had any Problem with Winbond Chips.
        • 20643
        Try NeoProgrammer software from this post. https://www.badcaps.net/forum/showpo...50&postcount=5
        There`s also a link to a 3.3V mod for the black pcb version,it can make it more stable.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1220
          • France
          I don"t use this programmer, but there is no problem with 5v instead of 3.3v on these models ??
          take the VCC voltage on the chip.
          https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod
          https://www.eevblog.com/forum/repair...75/#msg1323775
          at same time
          • onelook
            • May 2020
            • 27
            I have tried. Sadly no Success
            Current programmer: CH341a
            12:07:56
            Erasing memory...
            WARNING, probable erasure failure, check protection bits in status registers.
            Execution time: 00:00:00.061
            Old protection Register: 01000000(0x40),
            New protection Register: 01000000(0x40),
            I have read the Datasheet. There is 4K-bit secured OTP (see attached Picture)
            I will try later with the Volt measurement
            Thanks very much for your answers sofar
            • ahmedmph
              • Jul 2022
              • 4
              • United Arab Emirates
              mx25l12873f
              • ahmedmph
                • Jul 2022
                • 4
                12:07:56
                Erasing memory...
                How did you solve this problem, any suggestions?
                • rgomer
                  • Aug 2022
                  • Spain
                  Hi just found this forum searching for this chip and this thread point me in the right direction (I guess). The recommended tool up above (NeoProgrammer) almost worked, but still I wasn't able to write on the chip.
                  Using NeoProgrammer V2.2.0.10 I managed to write a new BIOS in this chip. Unfortunately seems like this didn't solve my problem (Gigabyte motherboard bricked because I enabled secure boot without an APU, only having a NVidia GPU).
                  Hope you guys have more luck.
                  • BHR
                    • Aug 2023
                    I just had the same problem on ASRock X370, bios would write but verification failed. I'm using Asprogrammer and CH341 with a clip. I download Neo but before I even ran it, chip would verify. What I did was erase the chip, read it (confirm all FFs), then write it again and verify. Not sure what the issue was, perhaps poor connection on the clip?
