Dell Latitude 7480 Bios Password
Re: Dell Latitude 7480 Bios Password
Ok, your laptop has a QWERTY keyboard, but these master passwords are calculated for a US QWERTY keyboard layout.Hi, my tag is J7TBQH2-E7A8, I have tried three different codes the one generated by https://bios-pw.org/ and two codes from a paid service. None is working. Keyboard is qwerty and used ctrl+enter and caps lock for upper cases.
Running out of options :-)
Is there any other options to explore?
Both of the master passwords for your laptop include OPEN BRACKET "[" key, which in a US QWERTY keyboard is located AT THE RIGHT OF "P" key, have you had that into account? Give it a try a few times.
Check picture attachment of US QWERTY keyboard and compare.
Attached Filesif you find these attachements useful please consider making a small donation to the site
Double check your keyboard layout as AAAC said. If you have a programmer back up your bios and post it here, updating the bios doesn't remove the password but I hope it changes the suffix so a different unlock code can be obtained.β΅
βhttps://www.badcaps.net/donateComment
AFAIK 8FC8 is a new suffix, meaning that only new Dell models will use this 8FC8 suffix*; E7A8 suffix is an updated suffix, an update from 6FF1 suffix which was released not too long ago as we know. For E7A8 a downgrade of the BIOS may cause to use 6FF1 suffix.
*I’ve seen models using 8FC8 suffix to use E7A8 suffix instead, probably a firmware bug.
Patching the BIOS may reset the Service Tag, and also the passwords.Last edited by AAAC; 12-25-2022, 08:41 PM.Comment
Thanks AAAC and hoaca388!Ok, your laptop has a QWERTY keyboard, but these master passwords are calculated for a US QWERTY keyboard layout.
Was the keyboard that caused the issue. Worked fine using the key to the right of the P for the right bracket.
Thanks for taking the the time to guide me!Comment
Can you please provide me for a bios password?
its : 3XQR6H2-E7A8
Tnx in advance xDComment
Hi! Any one could help on DELL 7480 BIOS PASSWORD
GDSG9H2-E7A8
I tried on bios-pw.org, their password don't work.
Thanks!!Comment
It's should works fine, just follow the Steps.
First Password: zmedD8p[4zd1Nh2z
Second Password: L451G0JqUc1zNsQm
Use an external (US) Keyboard (QWERTY), use shift key for Uppercase Letters, hold left CTRL key and press ENTER key twice.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
https://www.badcaps.net/forum/showpo...42&postcount=4
3.4. Dell
Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
See: https://beta.bios-pw.org/ .Enter the generated code using a US QWERTY keyboard and press
enter, or press the left control key and press enter ,or press the left control key and press enter enter.
Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97Comment
3.4. Dell
Thank you! Worked like a charm!! I've looked everywhere and no one said anything about this bug.Comment
Many -6FF1 machines are cracking with -BF97 codes. Simply exchange the suffix on data entry then generate your code.Comment
I guess you didn`t take any time to read any of the other posts in this thread.... see post #132Comment
Hello I have a problem can you help me please
I have a Dell Latitude 7480 FRA - Azerty
The System number is: 6DN41G2-E7A8
impossible to enter the password correctly I do not have an external keyboard in qwerty us...
I am attaching a picture of my keyboard
Thanks in advance for your help, I'm desperate....
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* βBIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, π π π ...-
by ElBock_Hello,
I just got my hands on an almost new dell latitude 7480. Issue is that its previous owner didn't give me the bios pasword.
Can you help me unlock it ?
System Number is FKL4SQ2-6FF1. I've already tried https://bios-pw.org/
Thanks !-
by anlsmithI am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
- Loading...
