Dell Latitude 7480 Bios Password
  • tuxerr
    • Dec 2022
    • 4
    • Sweden
    #121
    Re: Dell Latitude 7480 Bios Password
    Originally posted by hoaca388
    Update by a programmer.
    I have ordered a CH341A based programmer and will have a go at it :-).
    When updating via a programmer will the current bios admin pw be overwritten and reset to "blank"?
    • AAAC
      • Jan 2020
      • 459
      • Mexico
      #122
      Originally posted by tuxerr
      Hi, my tag is J7TBQH2-E7A8, I have tried three different codes the one generated by https://bios-pw.org/ and two codes from a paid service. None is working. Keyboard is qwerty and used ctrl+enter and caps lock for upper cases.
      Running out of options :-)
      Is there any other options to explore?
      Ok, your laptop has a QWERTY keyboard, but these master passwords are calculated for a US QWERTY keyboard layout.
      Both of the master passwords for your laptop include OPEN BRACKET "[" key, which in a US QWERTY keyboard is located AT THE RIGHT OF "P" key, have you had that into account? Give it a try a few times.
      Check picture attachment of US QWERTY keyboard and compare.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12438
        #123
        Double check your keyboard layout as AAAC said. If you have a programmer back up your bios and post it here, updating the bios doesn't remove the password but I hope it changes the suffix so a different unlock code can be obtained.
        ​https://www.badcaps.net/donate
        • AAAC
          • Jan 2020
          • 459
          • Mexico
          #124
          AFAIK 8FC8 is a new suffix, meaning that only new Dell models will use this 8FC8 suffix*; E7A8 suffix is an updated suffix, an update from 6FF1 suffix which was released not too long ago as we know. For E7A8 a downgrade of the BIOS may cause to use 6FF1 suffix.
          *I’ve seen models using 8FC8 suffix to use E7A8 suffix instead, probably a firmware bug.
          Patching the BIOS may reset the Service Tag, and also the passwords.
          • tuxerr
            • Dec 2022
            • 4
            • Sweden
            #125
            Thanks AAAC and hoaca388!
            Was the keyboard that caused the issue. Worked fine using the key to the right of the P for the right bracket.
            Thanks for taking the the time to guide me!
            • AnoDude
              • Dec 2022
              • 4
              • maroc
              #126
              https://beta.bios-pw.org/
              Change 6FF1 by BF97.
              Can you please provide me for a bios password?
              its : 3XQR6H2-E7A8
              Tnx in advance xD
              • miansh621
                Banned
                • May 2022
                • 133
                • pakistan
                #127
                its : 3XQR6H2-E7A8
                Tnx in advance xD
                1n2kbbdWUUILrGye
                [IkarnRrsLk46Day
                • diegho.maverick
                  • Jan 2023
                  • Argentina
                  #128
                  Hi! Any one could help on DELL 7480 BIOS PASSWORD
                  GDSG9H2-E7A8
                  I tried on bios-pw.org, their password don't work.
                  Thanks!!
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    #129
                    GDSG9H2-E7A8
                    Thanks!!
                    It's should works fine, just follow the Steps.
                    First Password: zmedD8p[4zd1Nh2z
                    Second Password: L451G0JqUc1zNsQm
                    Use an external (US) Keyboard (QWERTY), use shift key for Uppercase Letters, hold left CTRL key and press ENTER key twice.
                    all donations are welcome,
                    • diegho.maverick
                      • Jan 2023
                      • Argentina
                      #130
                      this makes the difference!! thank you!
                      • houtz68
                        • Feb 2023
                        need bios password for Dell Latitude 7480
                        9JMC2H2-6FF1 is the service tag.
                        Thank you!
                          • 22275
                          Thank you!
                          https://www.badcaps.net/forum/showpo...42&postcount=4
                          3.4. Dell
                          Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                          See: https://beta.bios-pw.org/ .Enter the generated code using a US QWERTY keyboard and press
                          enter, or press the left control key and press enter ,or press the left control key and press enter enter.
                          Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
                          • houtz68
                            • Feb 2023
                            3.4. Dell
                            Thank you! Worked like a charm!! I've looked everywhere and no one said anything about this bug.
                              • 22275
                              You`re welcome
                              • knivester
                                • Feb 2023
                                • Romania
                                #135
                                Hello!
                                Could you please help with a password reset for DELL 7480:
                                System number: 8ZB86H2-6FF1
                                I tried on bios-pw.org but their password doesn't work.
                                • lapfix
                                  • Mar 2020
                                  • 2764
                                  • my workshop
                                  #136
                                  Originally posted by knivester
                                  Hello!
                                  Many -6FF1 machines are cracking with -BF97 codes. Simply exchange the suffix on data entry then generate your code.
                                    • 22275
                                    Hello!
                                    I guess you didn`t take any time to read any of the other posts in this thread.... see post #132
                                    • _Lucas_
                                      • Feb 2023
                                      • Romania
                                      #138
                                      Thank you for all the info on this forum, very helpful.
                                      • wxcvbn
                                        • Mar 2023
                                        • france
                                        #139
                                        Hello I have a problem can you help me please
                                        I have a Dell Latitude 7480 FRA - Azerty
                                        The System number is: 6DN41G2-E7A8
                                        impossible to enter the password correctly I do not have an external keyboard in qwerty us...
                                        I am attaching a picture of my keyboard
                                        Thanks in advance for your help, I'm desperate....
                                        • wxcvbn
                                          • Mar 2023
                                          • france
                                          #140
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            11-08-2025, 10:04 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                            11-02-2024, 04:19 AM
                                          • ElBock_
                                            Dell Latitude 7480 bios password removal
                                            by ElBock_
                                            I just got my hands on an almost new dell latitude 7480. Issue is that its previous owner didn't give me the bios pasword.
                                            Can you help me unlock it ?
                                            System Number is FKL4SQ2-6FF1. I've already tried https://bios-pw.org/
                                            Thanks !
                                            06-13-2023, 08:42 AM
                                          • anlsmith
                                            Dell Latitude 5430 Bios Password
                                            by anlsmith
                                            I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                                            08-31-2024, 08:46 PM
