Dell Latitude 7480 Bios Password
    Re: Dell Latitude 7480 Bios Password
    Hi, I need a Bios admin password for this Dell Latitude 7390. Help would be much appreciated. DPR35Y2-E7A8
      wrong thread, use Search engine of this forum to find right thread for your Latitude 7390.
        Please Help Remove Password Dell 7480
        S-Tag CHD6PN2
          Can anyone help with a Dell latitude 7480 Password Please.
          S/N 3XZ5WT2-6FF1
          I have tried 2SQWwZZxcv4w2M2b and it doesn't seem to work.
          Thanks in advance.
            S-Tag CHD6PN2
            Sent to you !!
              S/N 3XZ5WT2-6FF1
              Thanks in advance.
              Try Password : Zmh[k1L9IsXU2L0n
                Brilliant, thank you so much.
                    Hello
                    Can somenone help me
                    Dell 7480 bios pass not working
                    4SXCNH2-6FF1
                    try this pass and say wrong pssword.
                    8b6rD3xvMMWXpMGc
                    thank you
                      Originally posted by pnvd View Post
                      Hello
                      4SXCNH2-6FF1
                      8b6rD3xvMMWXpMGc
                      thank you
                      BIOS guides, methods, resources and tools:
                      3.4. Dell
                      Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                      See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                      Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                      Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                      Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                      Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                      Note: There is no publicly available 8FC8 generator available at the moment.
                      The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        Originally posted by Vesko356 View Post
                        thank you very much
                          I have a problem with my Dell Latitude 7420 with servicetag and suffix:
                          HSBZR72-6FF1
                          Bios-pw.org generates this password for me: iBtf2nnGBBLC0MBz
                          In the BIOS i choose unlock and enter this password with control+enter and control+enter (twice)
                          It seems accepting this password. But after rebooting the laptop the Admin password is back on it and I again need to choose Unlock.
                          The passwords generated with the suffixes BF97 and 1F5A do not work at all.
                          So the initial generated password when choosing the 6FF1 as a suffix is the working password. But it is not saving my changes. Tried BIOS defaults and Factory Defaults already
                            Vesko356 commented
                            Editing a comment
                            Off topic! This thread is about Dell Latitude 7480!
                            In addition HSBZR72 is a Service tag for Dell Latitude E7470 not a "Dell Latitude 7420".
                            Read the rules please.
                          I have Latitude 7480. It was broken by corrupted BIOS.
                          I managed to repair bios with clean ME + clean bios from official site and put it together with uefitool. I copied EC and GbE region too from original broken bios.
                          Result: laptop is back to live except one thing.Ethernet LAN card has error 10 in Windows device manager.
                          I attach two bioses one broken + one fixed by me with error10 problem.
                          Can sameone take a look whats wrong?
                          Laptop MOBO: CAZ20 LA-E131P REV 2.0 A01
                          Servicetag: 1402QN2
                            Vesko356 commented
                            Editing a comment
                            Replace the bios region only, and don't "touch" ME Firmware.
                            BTW FwUpdateOemId key is zeroed in your "fixed" bios, i.e. your attempt to clean the ME Firmware is not quite correct/successful.
                          Vesko356 Replacing just BIOS region fixed everything.
                          FwUpdateOemId is zeroed right after I choose me region from repository in FIT dont know if thats normal process Im learning Cleaning ME thing so maybe im doing some error.
                          But DELL is back in action so thank you for pointing me in right direction.
                          Sorry for post under post but no edit button.
                            Hello!
                            Is there a simple solution for the E7A8 suffix? Failed on beta.bios-pw.org!
                            I just wanted give thanks to whoever wrote the "BIOS guides, methods, resources and tools" collection. My motivation for coming here was to unlock my Dell Latitude 7480's bios, which ended it -6FF1. And look what I read:
                            "Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97" - and for me the BF97 suffix worked!
                            The sad/funny thing is that even the official Dell support gave me the wrong unlock password, it differed in one character's capitalisation from the password generated by bios-pw.org. But both these passwords were wrong, but replacing the 6FF1 suffix with the BF97 suffix worked.
                            Thanks!
                              hi ... how to remove remote management on dell latitude 7480 please .
                              thanks
                                thanks
                                Read # 190
                                  Originally posted by hoaca388 View Post
                                  Read # 190
                                  sorry there's nothing there ...i'm talking about remote management not bios password
                                    By remote management do you mean Intel AMT or something else
