Dell Latitude 7480 Bios Password
  • ok67
    • May 2022
    Re: Dell Latitude 7480 Bios Password
    I have 1NF80X2-E7A8. Tried mentioned password generator. Received two passwords, held Ctrl and pressed Enter twice. Without success by both. User qwerty and qwertz. Used O instead of 0. Nothing helps.
    Any idea how to remove bios password ?
    Thanks in advance.
    • AAAC
      • Jan 2020
      • 459
      • Mexico
      #62
      @ok67
      • Post your generated passwords.
      • Count how many stars/asterisks are printed on the screen when you do the CTRL-ENTER-ENTER, there must be 16.
      • Upload a picture of the password screen. The master password works best at the System Password prompt โ€œThis computer system: #1NF80X2-E7A8, is protected by a password authentication systemโ€ฆโ€.
      • maikbi2pro
        • Sep 2021
        • 17
        • Россия
        #63
        Hello, I need help. Can someone clear me region in my dump? Thank you in advance.
        • mysticusa
          • Feb 2021
          • 11
          • United Kingdom
          #64
          Originally posted by hoaca388
          https://beta.bios-pw.org/
          Change 6FF1 by BF97.
          hi,
          HX5QNQ2-E7A8
          i got this code
          and gave me these
          JI[91J16dJZj4bLk
          DGyq2GzzRGL5c7dJ
          not worked.
          do i need to change the last 4 digits to some magic number or is there some sequence/conversion for this?
          thanx in advance
          edit: when typed lower case, it gives different pair of codes
          e0eyPQN12M516N3R
          [Qrr2mkp4IQQyn4G
          also doesnt work.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12438
            #65
            Originally posted by mysticusa
            hi,
            HX5QNQ2-E7A8
            i got this code
            and gave me these
            JI[91J16dJZj4bLk
            DGyq2GzzRGL5c7dJ
            not worked.
            thanx in advance
            e0eyPQN12M516N3R
            [Qrr2mkp4IQQyn4G
            also doesnt work.
            Enter password with a removable keyboard, qwerty US layout ,usb 2.0
            โ†ต
            โ€‹https://www.badcaps.net/donate
            • ok67
              • May 2022
              Originally posted by AAAC
              @ok67
              • Upload a picture of the password screen. The master password works best at the System Password prompt “This computer system: #1NF80X2-E7A8, is protected by a password authentication system…”.
              Hi, started to collect information but fully unexpected the generated password was accepted. It worked !!!
              The point is, I was on a business trip and used laptop keyboard. At home I used external USB keyboard. It could be a reason why the password was not accepted. Now is everything fine.
              Thank !
              • xamelion
                • Aug 2022
                • Kiev
                #67
                I have a dell 7480. code F401PH2-6FF1
                the WEBRctB5Uw8CbGZs on bios-pw.org doesn't work (I had tried it many times). pls, help me.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12438
                  #68
                  F401PH2-6FF1 change to F401PH2-BF97
                  โ†ต
                  • xamelion
                    • Aug 2022
                    • Kiev
                    #69
                    Many thanks, it works. Could you explain to me How or where I could read about it?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12438
                      #70
                      From Pro members of this forum.
                      โ†ต
                      • anothernoob
                        • Aug 2022
                        • 5
                        Evening, (well, it is here anyway) I'm a bit lost.
                        My system number is 16PPRQ2-6FF1
                        I've tried the number from bios-pw, I've changed the suffix to BF97 and tried that number too. neither work.
                        I don't have a US keyboard to try to enter it with that, is there anything else I can do to try and get rid of the pesky admin pasword?
                        Thanks in advance
                        • anothernoob
                          • Aug 2022
                          • 5
                          Thanks in advance
                          I forgot to say I've tried to press both enter, left ctrl & entre & right ctrl & enter.
                          and I've confirmed that there are 16 *s on the password
                          • volinakis
                            • Jan 2021
                            • 2876
                            • N/A
                            #73
                            Use right SHIFT key for uppercase
                            • anothernoob
                              • Aug 2022
                              • 5
                              Yes, yes, yes... Awwww shucks still no luck.
                              Thanks dude.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12438
                                #75
                                Thanks dude.
                                No, use Capslock for uppercase.
                                โ†ต
                                • anothernoob
                                  • Aug 2022
                                  • 5
                                  He shoots, HE SCORES!!!
                                  Thanks for your help hoaca388, using Capslock for the upper case letters worked a treat.
                                  I used the password for the 6FF1 suffix and it worked the first time.
                                  Have a great afternoon (or whatever time of day it is in your timezone)
                                  • volinakis
                                    • Jan 2021
                                    • 2876
                                    • N/A
                                    #77
                                    Thanks dude.
                                    I had 3 with Nordic layout and only in that way it worked, using right Shift for uppercase.
                                    • feherhollo
                                      • Nov 2019
                                      • 110
                                      • Hungary
                                      #78
                                      Dell Latitude 7480 Computrace
                                      Can somebody help me with computrace remove in dell 7480??
                                      I have dump!
                                      • feherhollo
                                        • Nov 2019
                                        • 110
                                        • Hungary
                                        #79
                                        Also can somebody explain how to or what to edit in the dump? Many Many thanks
                                        • lnkede
                                          • Jul 2022
                                          • Cameroon
                                          #80
                                          Hi. insearch of password for DB9X6S2-BF97. The bios provided by https://beta.bios-pw.org/ doesn't work. help me please
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * โ€‹BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            11-08-2025, 10:04 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, ๐Ÿ˜…๐Ÿ˜…๐Ÿ˜…...
                                            11-02-2024, 04:19 AM
                                          • ElBock_
                                            Dell Latitude 7480 bios password removal
                                            by ElBock_
                                            I just got my hands on an almost new dell latitude 7480. Issue is that its previous owner didn't give me the bios pasword.
                                            Can you help me unlock it ?
                                            System Number is FKL4SQ2-6FF1. I've already tried https://bios-pw.org/
                                            Thanks !
                                            06-13-2023, 08:42 AM
                                          • anlsmith
                                            Dell Latitude 5430 Bios Password
                                            by anlsmith
                                            I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                                            08-31-2024, 08:46 PM
