I REQUEST BIOS FROM Dell Latitude 3400
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    #61
    Originally posted by jj.ww
    hello. have tried that file, but no luck.
    still only get a flash of orange led when button press.
    do you think it will be a hardware fault ?
    double check the solder on the bios chip
    • jj.ww
      • Jan 2023
      • 21
      Hello I have reprogram and and resolder the bios chip still have the same problem.
      i have another 3400 which will only display the diagnostic colours if I hold down "D" and power on the unit.
      have tried to flash it with same file but no luck.
      cltr + esc and bios_rcv.bin does Nothing.
      any ideas
      thanks in advance.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        #63
        any ideas
        thanks in advance.
        can you give the motherboard imprinted model?
        • jj.ww
          • Jan 2023
          • 21
          hello it has,
          Bolt-L UMA MB
          17938-1
          FW8G6$LA
          • henrietta
            • Jun 2023
            • 6
            • Indonesia
            #65
            Hello can you fix this bios?
            Hdd and ssd not detected after windows crash
            dell latitude 3400 18750-1 R4GHW$JA
              • 21022
              Type and post the service tag. Rules - https://www.badcaps.net/forum/troubl...before-posting
              • henrietta
                • Jun 2023
                • 6
                • Indonesia
                #67
                ST 7VRPVZ2
                • minhdigital
                  • Nov 2022
                  • 758
                  • Vietnam
                  #68
                  ST 7VRPVZ2
                  Send to you, try
                  • henrietta
                    • Jun 2023
                    • 6
                    • Indonesia
                    #69
                    Originally posted by minhdigital
                    Send to you, try
                    Thank you, i’ll try it and let you know if hdd and ssd detection problem is solved
                    • henrietta
                      • Jun 2023
                      • 6
                      • Indonesia
                      #70
                      the ssd or hdd still not detected by bios i checked voltage all present but the sata and m.2 not detecting the storage
                      • Ariel2211
                        • Oct 2023
                        • 13
                        • Argentina
                        #71
                        Hello i need bios fix (black screen), i attach original bios corrupt.
                        Motherboard: 17938-1 fw8g6$la
                        DELL Latitude 3400
                        ST: 9MNDPW2
                        Thks
                        • LBTT1121
                          • Nov 2024
                          • 564
                          • Việt Nam
                          #72
                          DELL Latitude 3400
                          ST: 9MNDPW2
                          Thks
                          hi, try and feedback
                          • Ariel2211
                            • Oct 2023
                            • 13
                            • Argentina
                            #73
                            Hi, when programmer verify it says "Chip Main Memory with contents are in disagreement"
                              • 21022
                              The bios you posted is only 16.3KB compressed, and the file itself is badly corrupted. I think you are trying to backup the wrong chip. What model is your programmer and software version (i`m guessing CH341A) , did you choose Auto-detect or select the chip manually from the support list. What part number is etched on top of the chip. Are you using a clip. Is the bios chip SOP8 or WSON8
                              • Ariel2211
                                • Oct 2023
                                • 13
                                • Argentina
                                #75
                                Yes im using CH341A, software programmer 1.34. When i click detect the chip it shows 3 models 1)W25Q128BV 2)W25Q128CV 3)W25Q128FV what should i choose? At the top of the chip is etched "Winbond 25Q128JVSQ 2002".
                                  • 21022
                                  Use NeoProgrammer or ASProgrammer software instead, you`ll find both posted on the forum
                                  • techkid
                                    • Nov 2016
                                    • 20
                                    • philippines
                                    #77
                                    Originally posted by Markus1741
                                    File with latest ME Region 12.0.94.2380
                                    Me be it helps
                                    can you you give me Csme 12.0 repository or 12.0.93.2331
                                      • 21022
                                      links to repositories https://www.badcaps.net/forum/troubl...-guide?t=88533
                                      • Ariel2211
                                        • Oct 2023
                                        • 13
                                        • Argentina
                                        #79
                                        Thks, it works with NeoProgrammer.
                                        • puji_ilham
                                          • Aug 2022
                                          • 12
                                          • Indonesia
                                          #80
                                          Originally posted by SAHILSHAIK
                                          DELL LATITUDE 3400 CLEANED WORKING FILE WITHOUT SERVICE TAG
                                          THIS IS PERFECT !!!!!!!!! THANK YOU BROTHER !!!
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
                                          • DavidChunco
                                            Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                                            by DavidChunco
                                            Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                                            - Receive help from Dell Support (it is out of warranty).
                                            - Disconnect machine from AC power and battery overnight.
                                            - BIOS recovery process
                                            - Connected external display via HDMI
                                            - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                                            03-15-2025, 11:00 AM
                                          • Loli Popu
                                            DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                            by Loli Popu
                                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                            12-13-2024, 08:29 AM
