I REQUEST BIOS FROM Dell Latitude 3400
Hello I have reprogram and and resolder the bios chip still have the same problem.
i have another 3400 which will only display the diagnostic colours if I hold down "D" and power on the unit.
have tried to flash it with same file but no luck.
cltr + esc and bios_rcv.bin does Nothing.
any ideas
thanks in advance.Comment
can you give the motherboard imprinted model?Hello I have reprogram and and resolder the bios chip still have the same problem.
any ideas
Hello can you fix this bios?
Hdd and ssd not detected after windows crash
dell latitude 3400 18750-1 R4GHW$JAAttached FilesComment
Type and post the service tag. Rules - https://www.badcaps.net/forum/troubl...before-postingComment
ST 7VRPVZ2Attached FilesComment
Send to you, tryAttached FilesComment
Hello i need bios fix (black screen), i attach original bios corrupt.
Motherboard: 17938-1 fw8g6$la
DELL Latitude 3400
ST: 9MNDPW2
ThksAttached FilesComment
hi, try and feedbackAttached FilesComment
The bios you posted is only 16.3KB compressed, and the file itself is badly corrupted. I think you are trying to backup the wrong chip. What model is your programmer and software version (i`m guessing CH341A) , did you choose Auto-detect or select the chip manually from the support list. What part number is etched on top of the chip. Are you using a clip. Is the bios chip SOP8 or WSON8Comment
Yes im using CH341A, software programmer 1.34. When i click detect the chip it shows 3 models 1)W25Q128BV 2)W25Q128CV 3)W25Q128FV what should i choose? At the top of the chip is etched "Winbond 25Q128JVSQ 2002".
Use NeoProgrammer or ASProgrammer software instead, you`ll find both posted on the forumComment
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
Channel: BIOS Requests ONLY!
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... -
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
- Loading...
