Dell 7300 locked bios
Pls help to unlock Dell 7300
STAG:61NPM53
EDC30 LA-G861P
REV:1.0(A00)
2019-02-23
Thanks.Attached Filesif you find these attachements useful please consider making a small donation to the site
1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing modeAttached Filesif you find these attachements useful please consider making a small donation to the site
oh i'm sorry i uploaded incorrect file. here is the correct one.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hey there.
Now to the results.
flashed in the file and verified the flash went good. worked perfectly, went into FACTORY MODE.
but now to the odd thing:
While in factory mode, and entering the service tag, the computer dies randomly before I got to save the service tag, it just rebooted in the middle of entering it.
Tried again, went into factory mode, started entering service tag but it then died randomly again. (both times on DC power).
Now it just turns on, fans on full speed, caps lock LED on.
no beeps.
Display test (D key) works.
Tried reflashing the file again (I could see that the file does not match anymore, so the computer writes something to the BIOS).
Same result.
Verifying the BIOS chip shows that the content is again changed, so apparently it can boot the bootloader for the BIOS chip.
I guess there is some hardware fault on the computer, so any ideas what it could be?
Here is how the computer behaves:
On DC only: Computer reboots every like 30 seconds, fans full speed, caps lock LED on, screen black.
On battery only: Computer is stable, but screen is black all the time. Have had it on for like 15 minutes.
On DC + Battery - same as Battery only.
Tried both with BIOS battery attached and detached.
Any ideas what could be the problem?
Just wondering if you got it all sorted out ? I'm having a similar issue..
How did you go programming the 25B256 with the CH341a programmer ( i believe it was showing as a 25Q256 ) ? and did you program it on or off the board ?
ThxComment
can you unlock this file plz
service tag
99VYY2
https://www.badcaps.net/donateComment
Dell latitude 7300
can someone pls unlock this bios for mE
service tag 40MJP13Attached Filesif you find these attachements useful please consider making a small donation to the site
UNLOCK TRYAttached Filesif you find these attachements useful please consider making a small donation to the site
Witam,
czy ktoś z Was może mi pomóc odblokować BIOS w moim Latitude 7300?
service tag : JVSZP13
Z góry dziękuję
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
