Dell 7300 locked bios
Pls help to unlock Dell 7300
STAG:61NPM53
EDC30 LA-G861P
REV:1.0(A00)
2019-02-23
Thanks.Attached FilesComment
oh i'm sorry i uploaded incorrect file. here is the correct one.Attached FilesComment
Now to the results.
flashed in the file and verified the flash went good. worked perfectly, went into FACTORY MODE.
but now to the odd thing:
While in factory mode, and entering the service tag, the computer dies randomly before I got to save the service tag, it just rebooted in the middle of entering it.
Tried again, went into factory mode, started entering service tag but it then died randomly again. (both times on DC power).
Now it just turns on, fans on full speed, caps lock LED on.
no beeps.
Display test (D key) works.
Tried reflashing the file again (I could see that the file does not match anymore, so the computer writes something to the BIOS).
Same result.
Verifying the BIOS chip shows that the content is again changed, so apparently it can boot the bootloader for the BIOS chip.
I guess there is some hardware fault on the computer, so any ideas what it could be?
Here is how the computer behaves:
On DC only: Computer reboots every like 30 seconds, fans full speed, caps lock LED on, screen black.
On battery only: Computer is stable, but screen is black all the time. Have had it on for like 15 minutes.
On DC + Battery - same as Battery only.
Tried both with BIOS battery attached and detached.
Any ideas what could be the problem?
Just wondering if you got it all sorted out ? I'm having a similar issue..
How did you go programming the 25B256 with the CH341a programmer ( i believe it was showing as a 25Q256 ) ? and did you program it on or off the board ?
ThxComment
Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Dell latitude 7300
can someone pls unlock this bios for mE
service tag 40MJP13Attached FilesComment
Witam,
czy ktoś z Was może mi pomóc odblokować BIOS w moim Latitude 7300?
service tag : JVSZP13
Z góry dziękuję
Attached FilesLast edited by Marcel Markefka; 12-25-2024, 05:56 PM.Comment
Channel: BIOS Requests ONLY!
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
- Loading...
