HP ZBOOK 14U G6 Bios Password
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: HP ZBOOK 14U G6 Bios Password
workingAttached FilesComment
Hello friends I have managed to put the DMI info except system board-feature byte, if I put it its saying invalid crc failed but I am taking the info from HP Partsurf website, I have tried to use UEFI Tool but I can't see which part of the ME region is containing the dmi info so I can copy it from the original file. I have attached screen shots and also both files. Is there any other way to do it I will be grateful for your help. ThanksComment
Hello there, thank you to whoever will be kind to look into this.
I need a bios password removal for a Zbook 14u G6, SN 5CG9516ZPT and not sure if this is the mobo identification you are after (hope so) M/B SPS:L65694-601
I attach my 32,768 KB file which is the only one I managed to locate and extract for now, hoping it's the only one needed. I tried to read as much as possible on the forum and I have already
downloaded the 6050A3022501-MB-A01sound fix final flash.bin file that, from what I gather, could be already what I need... but since I'm so crap at soldering I would prefer to write the bios and re-solder it once only!!
Thanks a million, Jedeone
zbook_14uG16_locked.zip
[ATTACH]n3250122[/ATTACH]
I don’t know what amazes me more, that I managed to desolder and resolder the bios without screwing up chip and motherboard, or that I stumbled upon this incredible forum with people like Quayyum786, thanks whoever you are wherever you are, it worked perfectly !!Comment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by beBossHi,
as noobie to this please excuse my lack of experience.
I am trying to remove a BIOS password from this machine:
HP ProDesk 400 G6 Mini
but so far I still have no success.
I bought CH341 programmer and decided to give it a try.
The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...-
- Loading...
