Panasonic CF53 MK4 CF-532S74RMG
Every donation made will go towards server fees and maintenance costs. -
Re: Panasonic CF53 MK4 CF-532S74RMG
i have a toughbook CF-53 mk4
Windows is booting from an USB-Stick, but it is bios locked
Serial: - CF-532nxbymg
Aptio 4 Ami delivers me a 6 MB file
can someone unlock it?
I try to upload it with Aptio4Ami, is that working?
or what is the solution without opening the laptop-case
byeAttached FilesComment
Try the Attachment and report.Attached FilesComment
Hello Guys, could you help me please? I have a CF-53 MK4 with an pw.Attached FilesComment
Try the attached file...Comment
Hi guys I have a Bios locked Panasonic CF-53 MK4
Model:CF-532SLZACM
S/N: 6CTSA56886
Need Mac Adress to match pleas and ME Firmware to match
If you guys can make it boot with the "Panasonic" logo that would be great too thank you!Attached FilesComment
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
cf-532s74rmg
s/n:5ktca37214Comment
try it with a 64 bit windows OS, w10 (64 bits), it solved mine problems working on a cf-19 mk4. Use CH341A Mini Programmer V1.29 with the 64 bit drivers. And be sure the clam on the chip is fitting WELL.Comment
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
